I installed the new Mini tool head v2.1. The end stop switch that is on the new tool head, right hand side (the other end stop is on a plastic piece by the threaded rods on the left side, not on the tool head) is only touching the plastic piece 1/4 on the switch which is not enough to trigger the switch. It looks like when the plastic rod holder was printed the end stop tapered near the bottom, not making contact with the new switch. The stop switch is good, I tested it by pressing it in and trying to move the print head in Cura. Any ideas on how to fix this?
Epoxy a thin piece of plastic to the x carriage which will hit the limit switch.
Thanks I will do that. I also need to learn Blender then I can make a clip!
