New lulzbot mini. Trying to use a netbook to control it, but each print gets stuck between layers one and five. Typically at layer two. The print head just stops moving, with no additional filament feed. Bed and nozzle temperatures remain constant. Pausing and resuming has no effect. No error messages occur.
A second laptop hasn’t had the same problem. Settings were identical between runs and the same model (rocktopus) was used. The laptop is grounded while the netbook is not. One netbook run stopped at the moment that someone touched the case and statically discharged. Grounding the case did not resolve the issue. Running with the netbook unplugged from power did not resolve the issue.
Any advice?
