I received the Mini today and tried two model. The printed model looks good, but I found a problem in both models. The problem is that there always no melted filament when the printer starts to print. After a short time, the melted filament came out. So the first layer is not complete. I tried to reduce the retract distance from 6.5 mm to 4.5mm, but the problem is still there. How to solve that?
Could you please show me how to modify the G-code in Cura to make it prime better? I’ve tried, and failed, a lot. I’ve learned to print a lot of skirt which almost always works, but what a waste of time and materials.
Is this the line I modify? And what do I change? I’m not a G-Code type of person, but hoping to learn. Thanks!
