Printing on top of paper?
If my Z-offset is -1.19 and I need to print on material that is .1mm thick, do I just add those dimensions and change Z-offset to -1.09?
You can! Also remember to clamp it down or it will curl right up off the bed as the material cools. :laughing:
Tried printing PLA on some laser printer paper but not good adhesion… just flaked off. What build plate temp do you use? Paper? Filament?
