Z-Offset Adjustment?
mhr_lulzbot
Contact:
Post by mhr_lulzbot » Fri Aug 10, 2018 11:49 am
Noob question:
Are the Z irregularities in the attached image normal or might the Z-Offset need to be fine tuned?
Lulzbot Mini 2, Windows 10, RasPi 3+ w/ Camera v2, Epilog laser, CNC, Instagram: melristau, "Here's your beautiful brain. Here's your brain on Age."
mikehill85
Re: Z-Offset Adjustment?
Post by mikehill85 » Sat Aug 11, 2018 3:52 pm
It looks to me like you're either over-extruding or too close to the bed. You can easily check your z-offset using M501, change it with M851 and save the change with M500 (in case you didn't know). Check your filament diameter. It may be larger than what your slicer is set for. Also I would check my extrusion multiplier in my slicer. It might be set over 100%
mhr_lulzbot
Contact:
Post by mhr_lulzbot » Sat Aug 11, 2018 8:45 pm
Thanks! I'll check. I know my z-offset was set at -1.19 before it shipped...
Will read more. (Have yet to send g-code directly to printer.)
