X-Level
mhr_lulzbot
Contact:
X-Level
Post by mhr_lulzbot » Tue Sep 18, 2018 9:51 pm
When X-Level-ing, the nozzle is not supposed to touch the back right washer: Correct?
Lulzbot Mini 2, Windows 10, RasPi 3+ w/ Camera v2, Epilog laser, CNC, Instagram: melristau, "Here's your beautiful brain. Here's your brain on Age."
NBradshaw
Re: X-Level
Post by NBradshaw » Wed Sep 19, 2018 8:37 am
I'm not sure if you are referring to leveling the x-axis on the Mini 2, or if you are using another printer, but on the Mini 2, the level x-axis option should not hit the back right washer. It will get a bit close, but it should not make contact.
mhristau
Contact:
Re: X-Level
Post by mhristau » Wed Sep 19, 2018 8:57 am
OK Thanks
Yes, Mini2
I ask because I've been printing parts with the same profile / same filament but having to change z-height to get a good first layer. Varies from 1.09-1.11. Not sure why.
monsteroyd
Re: X-Level
Post by monsteroyd » Mon Oct 01, 2018 2:39 pm
Is this the Z-offset? or something else that you are fiddling with? On my Mini2 the Z-offset is the distance in mm from the top of the washer at the corner to the PEI/glass bed.
Thanks
Monty
Lulzbot Mini 2
