Converting a TAZ 5 single extruder for mini
spei
Post by spei » Thu Jan 24, 2019 10:07 am
Has anyone tried to converting a TAZ 5 single extruder 0.5 mm to a single extruder for LulzBot Mini? Thanks for the help!
johnson
Re: Converting a TAZ 5 single extruder for mini
Post by johnson » Sat Jun 08, 2019 4:45 pm
I really wouldn't recommend using a TAZ 5 tool head on a Mini. The reason is that the tool head is a different dimension and the firmware won't differentiate the difference. Your printer will think that you have a Mini tool head and this can cause some potential physical damage to your printer.
That being said, if you have a V2C extruder with a V2 0.5 mm hexagon hot end, you can switch that out with the Mini 1's hot end assembly.
There are some helpful instructions that you can use for a guide here: https://ohai.lulzbot.com/project/replac ... e-repairs/
bbc0
Post by bbc0 » Thu Jun 13, 2019 10:28 am
I purchased my mini used and it came with a separate Taz printhead. Not sure why. The components seem to be the same as the mini printhead just mounted on a different backplate. Is this really not the case? Maybe there are hidden differences.
mwester
Post by mwester » Thu Jun 13, 2019 7:40 pm
The old taz-5 print-head was based on a buddaschnozzle hot-end; the newer taz print-heads and the mini heads are all based on the hexagon hot-end.
The differences between the taz version with the hexagon hot-end and the mini version are minor - the biggest mechanical differences are the mounting plates, and the connector -- and the taz unit has a pair of cooling fans.
Note that there are two different versions of the hexagon hot-end for both the taz and the mini. The older has a tiny little heat-sink cooling fan, the newer has a larger fan. The difference is actually a bit more involved between the two; other parts fit a bit differently as well. I'll not go into the details here, but I've converted several print heads over the past few years -- one of them twice (turned a damaged mini print head I picked up for a song on eBay into a flexystruder for my mini, then when I got a Taz 6, I converted it into a flexystruder for the Taz. I've also built a couple of extruders from spare parts -- much cheaper than buying them. So the point is that if you have the hexagon hot-end, you can easily construct either a Taz or a Mini print head.
bbc0
Post by bbc0 » Fri Jun 14, 2019 10:34 am
What is a ‘flexistruder’ and how does it differ from a normal extruded?
mwester
Post by mwester » Fri Jun 14, 2019 4:00 pm
It's a variation of the standard extruder that is capable of handling flexible filaments.
Alas, while it does a great job with flexible filaments, it can't do traditional filaments -- so you needed both prior to the introduction of the aerostruder (which effectively obsoleted both of the older hexagon-hot-end extruders).
