Printing question - Flat Surfaces
mdivancic
Post by mdivancic » Sun Mar 03, 2019 6:39 pm
When I print models with flat tops the surface is not smooth but has a pattern in it. I've seen prints from other printers and the tops look smooth. Any advise to get a smooth top surface?
Regards,
Mike
Regards,
Mike
ritmopat
Re: Printing question - Flat Surfaces
Post by ritmopat » Mon Mar 04, 2019 6:55 pm
check the iron command in cura
mdivancic
Post by mdivancic » Wed Mar 06, 2019 6:17 pm
OK, how come this setting is hidden. I couldn't find it in any of the setting advanced options, but when you search for Iron the setting is available and can be adjusted. What's the reason for this?
Regards,
Mike
Regards,
Mike
ritmopat
Post by ritmopat » Wed Mar 06, 2019 6:23 pm
you have to click the little gear to open the commands window then click iron to have it show .... I believe....
mdivancic
Post by mdivancic » Wed Mar 06, 2019 6:36 pm
Did that, fairly straight forward. Not visible. Only shows up when I search for it using the search command above the advance settings.
Regards,
Mike
Regards,
Mike
Brent.I
Post by Brent.I » Thu Mar 07, 2019 9:19 am
Some of the settings are hidden by default. To configure which ones are visible by default, go to Settings > Configure Setting Visibility >
You can then selection which ones you want to see, or can select all in the top left corner.
mdivancic
Post by mdivancic » Thu Mar 07, 2019 6:53 pm
Cool, thanks!
Regards,
Mike
Regards,
Mike
mdivancic
Post by mdivancic » Mon Mar 18, 2019 4:51 pm
New flat surface question. If I print something like a cube the vertical surfaces are wavey, they show some offset in the x and or y direction. Is there an adjustment I can make to tighten this up. I'm running a mini 1.4 version, stock.
Regards,
Mike
Regards,
Mike
piercet
Contact:
Post by piercet » Tue Mar 19, 2019 2:17 pm
Regards,
Mike
With your printer cold, move the nozzle out into the middle of the frame so you can get at it. Now try moving it forward and back and side to side. If there is any movement play at all, adjust your bearing blocks and tighten screws and shim parts as needed until the play is removed but the head still moves smoothly. Repeat with the bed.
