Musical Instruments
Posted: Mon Jul 24, 2017 10:24 am
by gyukish
Link: https://www.thingiverse.com/thing:1735985
License: CC BY 3.0
Grade Level: 5-8
Courses: Music
Here are three models that make up two musical instruments. The first two models are two parts of an Ocarina. The second model is a Pan Flute.
Ocarina Part 1
Posted: Mon Jul 24, 2017 10:55 am
by gyukish
Link: https://www.thingiverse.com/thing:234512/#files
License: CC BY 3.0
Grade Level: 5-8
Courses: Music
This is the first part of the Ocarina model. Be sure to use support with this. This part will take about one hour and forty-five minutes to complete on high speed. Please note that the original model is in inches. When you load the model into Cura it reads the model in millimeters. Instead of the model being 4.2 inches long it reads as 4.2 millimeters long. To fix this simply click on the model, select scale in the lower left, ensure that uniform scaling has been selected, it defaults to this. With uniform scaling on change the scale X from 1 to 25.4. This will scale everything up to the proper dimensions.
Ocarina Part 2
Posted: Mon Jul 24, 2017 10:56 am
by gyukish
License: CC BY 3.0
Grade Level: 5-8
Courses: Music
This is the second part of the Ocarina model. Be sure to use support with this part. This part will take about two hour and twenty minutes to complete on high speed. Please note that the original model is in inches. When you load the model into Cura it reads the model in millimeters. Like with the first part, to fix this simply click on the model, select scale in the lower left, ensure that uniform scaling has been selected, it defaults to this. With uniform scaling on change the scale X from 1 to 25.4. This will scale everything up to the proper dimensions.
Pan Pipes
Posted: Mon Jul 24, 2017 11:03 am
by gyukish
Link: https://www.thingiverse.com/thing:1735985/#files
License: CC BY 3.0
Grade Level: 5-8
Courses: Music
This is a model for Pan Pipes. This model will take about three and a half hours to complete on high speed.
Re: Musical Instruments
Posted: Tue Aug 01, 2017 9:42 am
by piercet
Posted: Tue Jan 23, 2018 11:48 am
by Ernesto Renteria
Someone can help me, in the download list I found an impossible gear, but the file is one piece. Does anyone have this file in separate parts? I need it to print the pieces individually.
Posted: Tue Jan 30, 2018 8:31 pm
by crazymag
I will try to create one as well I hope that it will work fine.
