Cura LulzBot Edition version 3.2.11: Alpha Testing
Testers and bug catchers needed! Help contribute to Free Software development by testing pre-release versions.
Locked
Brent.I
Post by Brent.I » Fri Mar 02, 2018 1:26 pm
Your mission, should you choose to accept it: Help drive Free Software development further by using the latest test versions of Cura LulzBot Edition (Cura LE)!
Our software team is hard at work developing Cura LulzBot Edition, version 3.2.
This alpha development version of Cura LE has passed our internal smoke tests on multiple operating systems. We need your help testing real-world use-cases across various platforms.
Things to remember:
  • These versions are not final
  • New features may be broken
  • Existing features may change or perform differently
  • Your feedback, bug reports, and other contributions will be appreciated.
Development Version: 3.2.11
Release Type: Alpha
Dev Branch Release Notes
Cura LE v3.2.11, Alpha: Discussion Thread
Cura LE v3.2.11, Alpha Slicing Profile Discussion Thread
Cura LE: Feature Request Thread
Step 1: Remove Existing Cura LE Versions
Debian and Ubuntu Linux:
Open terminal and run the following commands to remove the existing Cura LE version:
Code: Select all
sudo apt-get remove cura-lulzbot
Clear Cache Files:
Code: Select all
rm -rf ~/.cache/cura-lulzbot ~/.config/cura-lulzbot ~/.local/share/cura-lulzbot
Windows:
Uninstall Cura:
  1. Open Add or remove program
  2. Select cura-lulzbot
  3. Select Uninstall.
Remove Cached Settings:
  1. Open your File Explorer. In the address bar, type:
    Code: Select all
    %appdata%
  2. Press the Enter Key.
  3. Delete the cura-lulzbot folder, if present, by right clicking on cura2_lulzbot and selecting Delete.
  4. In the address bar, type:
    Code: Select all
    %localappdata%
  5. Press the Enter Key.
  6. Delete the cura-lulzbot folder, if present, by right clicking on cura2_lulzbot and selecting Delete.
Verify that the following folders are no longer present after uninstalling Cura LE:
  • C:\Program Files (x86)\cura-lulzbot 2.6
  • C:\Program Files\cura-lulzbot 2.6
  • C:\Users\username\AppData\Local\cura-lulzbot, shortcut:
    Code: Select all
    %localappdata%
  • C:\Users\username\AppData\Roaming\cura-lulzbot, shortcut:
    Code: Select all
    %appdata%
Replace username with your username. The version number will vary depending on the version of Cura LE installed.
OSX
Uninstall Cura:
  1. Open Finder
  2. Select Go
  3. Select Applications
  4. Select Cura
  5. Select the File menu
  6. Select Move to Trash
Open Terminal and run the following command:
Code: Select all
rm -rf ~/Library/Application\ Support/cura-lulzbot
Step 2: Install Development Version of Cura LulzBot Edition
  1. Download and install the current testing version of Cura LE.
    Note: Linux users should only use one active repo at a time, specifically the devel branch. Comment out the stable download branch.
  2. Open Cura LE.
Step 3: Use Cura LulzBot Edition and Document Your Experience
If you run into any issues, we would like to hear all about it! We will need the following information to help locate and fix the issue:
  • Operating System
  • Video card and driver version (for any grapical issues)
  • Version of Cura LE
  • Printer Firmware Version, found by typing M115 into the console while connected, or displayed on the Graphical LCD controller
  • Steps to reproduce
  • Attach the Cura LE Error Logs, found at:
    Windows:
    Code: Select all
    %localappdata%\cura-lulzbot\3.2\cura-lulzbot.log
    Code: Select all
    %appdata%\cura-lulzbot\3.2\cura-lulzbot.log
    Linux:
    Code: Select all
    ~/.local/share/cura-lulzbot/3.2/cura-lulzbot.log
    Mac:
    Code: Select all
    ~/Library/Application Support/cura-lulzbot/3.2/cura-lulzbot.log
    Step 4: Submit Your Feedback
    Once you have the above information, open a ticket on our Cura LE task and bug tracker:
  • How To Submit A Bug Report: Code.AlephObjects.com
  • Submit Bug Report
    After your feedback is posted, we will work to duplicate the issue, identify the cause, and roll those improvements into the next version of Cura LulzBot Edition.
Locked
