PEI bed surface
Have questions? Want advice?
unxetas
PEI bed surface
Post by unxetas » Sat Jul 12, 2014 12:12 pm
Folks - I had been following a looong thread on SeeMeCNC about using a sheet of PEI as a bed surface on 3D printers. Everyone kept saying it was a miracle material - people were easily able to print both PLA and ABS, with a heated bed of course, with perfect adesion but easy extraction once the bed cools off enough. No glue, no ABS juice, no treatment whatsoever other than keeping it clean.
Well, I finally tried it out last weekend.. Got a 0.040" thick sheet from McMaster-Carr, along with a 12"x12" sheet of 3M 468MP transfer adhesive. Removed the PET from the TAZ's bed and went to town gluing the PEI down. It definitely takes a bit of careful work to adhere it nice and flat.
I readjusted my bed level and height and.. Voila! I'm printing some fairly big parts (the TAZ 4 Z motor mounts, top plates, etc) with perfect adhesion, no warpage. These are long flat parts with sharp corners and I'm using quite a bit of infill to make them stiff. It is a night and day difference to what I went through trying to get ABS to stick to the PET tape, even with ABS juice. I haven't printed with PLA yet, but from what I've read, that will be no trouble at all!
It's also fairly thick and strong, so it will take quite a lot of effort to mess it up. So far, I'm super happy with this upgrade and whole heartedly recommend it to anyone having trouble with getting their parts to stick!
piercet
Contact:
Re: PEI bed surface
Post by piercet » Sat Jul 12, 2014 11:56 pm
This has been on my list of upgrades to try for a while now. I've just never got around to actually ordering it. About how much did the adhesive and the PEI run you if you don't mind me asking, and how does the adhesive seem to be holding up to the heat?
unxetas
Re: PEI bed surface
Post by unxetas » Mon Jul 14, 2014 9:24 pm
Don't mind at all - I bought the adhesive from Digikey for $5.50 or so, IIRC.. That's for a 12x12" sheet. Most folks have been buying a thinner roll from Amazon as it's easier to manage - I believe a a 15 yard roll of 1 or 2" adhesive is 6 or 7 bucks from Amazon as well. I actually bought both the sheet and the roll just in case I messed up the 12" square sheet :) There were quite a few bubbles, but I used an x-acto knife and made little cuts on each bubble. The plastic is thick enough that any remaining irregularities are unlikely to transfer to the surface, though!
I bought the PEI from McMaster.. Again i ordered too much just in case, and bought a 12x24" sheet - I think it was around $35? I think the 12x12" sheet is around $20.
The adhesive is holding up great so far. I've printed maybe half a roll of ABS and a bit of PLA, so I don't want to promise that this will last forever, but some of the guys on the SeeMeCNC forum (particularly Michael Hackney) have printed on the same sheet for weeks of intensive printing, using the same adhesive, so I'm hopeful it'll hold up :)
The bit of PLA I printed was just an hour ago - a fairly large, flat part 4" x 7" roughly. I heated up the bed to 60deg and let her rip, worked great. No lifting, everything stuck perfectly and came off easily once the bed cooled down enough :)
piercet
Contact:
Re: PEI bed surface
Post by piercet » Tue Jul 15, 2014 8:50 am
Huh, alright, I'll give this a shot!
Edit, parts on the way. Ended up getting the adhesive from Amazon. SHould all be here in a few days.
piercet
Contact:
Re: PEI bed surface
Post by piercet » Sun Jul 20, 2014 8:53 pm
This stuff is Magical. Go buy some and do this mod today. Go ahead, I'll wait.
I got my parts in this weekend and proeeded to install it on the existing glass plate using the adhesive outlined above. It went on in about 10 minutes. I had to trim the plastic square to match the plate a bit, but I was able to do that with a pair of sheet metal shears easily enough. I've printed 4 things on it so far, and it all sticks like glue until the bed cools down, then it pops off like nothing. I've tried almost all of the alternative bed materials people have proposed so far, and this is by far the best one I've tried yet.
Next up I think i'll get a 3mm aluminum plate and attach a new lulzbot 24v heater to the bottom of the plate to try and save some mass on the Y axis. Definitly no downside so far to this modification, at least for printing with ABS.
Orias
Re: PEI bed surface
Post by Orias » Mon Jul 21, 2014 7:10 am
Sweet!
Thank you for the updates!
unxetas
Re: PEI bed surface
Post by unxetas » Mon Jul 21, 2014 8:29 pm
Awesome :) glad it's working well for you! Let us know how things go with the aluminum plate.. In my experience, it might be hard to find a plate of aluminum that thin that is and stays as flat as a piece of glass.. But it would be a great way to save weight!
piercet
Contact:
Re: PEI bed surface
Post by piercet » Mon Jul 21, 2014 9:47 pm
I've got a piece of 4mm aircraft grade milled aluminum plate on my AO-10x at the moment and it seems to do ok at the smaller size. It's on a rigid plate bed though. the larger 24v taz nonrigid silicone bed might require something thicker. Will have to try it and see
gapdev
Re: PEI bed surface
Post by gapdev » Tue Jul 22, 2014 1:33 pm
The .040 PEI is pretty thick. How well does it conduct heat? Do you have to raise the bed temperature any?
Amazon has 12x12 in sheets of 3M 486MP adhesive in 6 packs for a pretty reasonable price.
http://www.amazon.com/gp/product/B007Y7D5NQ
Kenny
piercet
Contact:
Re: PEI bed surface
Post by piercet » Tue Jul 22, 2014 2:33 pm
I didn't notice any need to increase the temperature at all. I actually think I could probably lower it quite a bit and it would still stick just fine. This stuff is just that sticky!
I actually bought my sheets from that amazon listing, but they only had one more in stock so I put the digikey listing in there instead.
