My Lulzbot Taz 6 starts to print then stops saying probing bed or the bed leveling failed and keeps re-wiping the nozzle. I’m using PLA ooznest 1.75mm if that makes any difference.
If you’re just getting started with the LulzBot TAZ 6 we highly recommend using 3 mm filament. If you’re getting that error, replace your nozzle wiping pad (written for LulzBot Mini users, you’ll do something similar): https://ohai.lulzbot.com/project/mini-wiper-pad-replacement/maintenance-repairs/
Reach out to the support team for detailed help if replacing your wiper pad doesn’t help: https://LulzBot.com/Support.
I’ve changed it still nothing. I’ve used a scotch pad and i have also measured that the axis point to make sure they are the same.
Reach out to the support team at https://LulzBot.com/Support, include as many pictures as you can, and information on your slicer and material profiles used. They’ll be able to offer detailed help for your particular situation.
