Could you give a shout here when the Buda 2.0 is ready to ship from Toronto? No rush, I can wait, I just want a spare hot end as it was suggested to me. Actually once I have a v2.0 in hands the v1.1 on my AO-100 will for sure end as the spare.
It looks like we only have the Budaschnozzle 1.1-1.3 heater block in stock in Toronto at this time. We try to keep everything in all three warehouses. Most of the other spare parts are in stock in the US and the UK.
The heater block is what I wanted. Mostly it’s for aesthetic reasons. I slightly damaged my heater block when removing the nozzle because the 18mm wrench only fit the first 5mm. I had to use an adjustable wrench. I measured the heater block with a caliper and it is 18.3mm wide. It seems it expanded under the heat. It’s still fully functional though.
Edit: I see the Buda 2.0 has finally been processed in Toronto! Cool!
