ROUGH PRINTS>?? weird...
Have questions? Want advice?
mhackney
Re: ROUGH PRINTS>?? weird...
Post by mhackney » Thu Mar 12, 2015 8:34 pm
Did you check to make sure the path through the extruder, the aluminum mount plate and hot end are aligned? Push a prince of filament though from the top and feel for a clear path or snags. Also, is your hot end oozing? Its a known issue with Budhashnozzle and pretty easy to fix. I'm sure your issue is correlated with the disassembly / reassembly of the hotend and those two items are prime suspects.
Sublime Layers - my blog on Musings and Experiments in 3D Printing Technology and Art
Start here:
A Strategy for Obtaining Great Prints
Strategies for Resolving Print Artifacts
The Eclectic Angler
JonathanB
Post by JonathanB » Fri Mar 13, 2015 12:13 am
JonathanB
Post by JonathanB » Fri Mar 13, 2015 10:06 am
Ok guys,
So it looks like the source of the problem was indeed the filament....which makes a lot of sense. here's the reply I got from filaments.ca
__________________________________________________________________________________________
Hi Jonathan,
Thank you for your email. I am sorry you are having issues with the ABS.
The creative series filaments were unfortunately prone to some quality
issues and we have since stopped producing it. If possible, please send
us a picture of the issue you are experiencing as well a picture of the
spool itself with the label on it for our records.
In the meantime, I am shipping you a free replacement from what we have
left in stock of this filament.
*edit, they are selling what's left of the creative series stock and then discontinuing it. They're sending me a replacement roll of the standard ABS stuff..
Brew4You
Post by Brew4You » Fri Mar 20, 2015 11:21 am
I've been using ORDSolutions ABS filament the first roll made pretty rough prints but I chalked it up to being a n00b. The beginning of the second roll I was able to make prints like this
Dang pretty looking, dimensionally sound, with only a couple of minor uglies on bridges and steep overhangs.
And now I'm having trouble even doing this--can't even get through the 45° section, which is leading me to start putzing with slicer settings and machine calibrations
Makes for a rough looking print, that don't stick to the bed as well as they used to
But the bottom of the spool looks like this. So maybe I should just pull the roll of and load in some better filament as a first test.
Filament on the spool is lookin' real rough. Lots of kinks and stress marks
So in short I would say Yeah filament quality is a big factor in how prints turn out. But here is a case for having a "well oiled and tuned" machine.
bearings & hardened shafts and the hexagon nozzle on the right. Stock TAZ 4 on the left.
These prints were done in series with the same filament (ORDSolutions ABS white) from the same spool with the same .gcode. All the above prints were done with the modifications and from the same spool.
JonathanB
Post by JonathanB » Fri Mar 20, 2015 12:25 pm
Haha, that roll of filament looks nasty!
you can still print with bad filament, just makes it a lot harder to dial things in, and its hard on the extruder parts because the oversized oval parts stress the tensioner.
I can't wait to swap my bearings and rods, I ended up sourcing rods from a local general bearing For like half the cost! Not sure why I didn't think of that in the first place...
BaltimoreBully
Post by BaltimoreBully » Sat Mar 21, 2015 8:49 am
Is there any other reason to change brands of filament other than price? I have only had the printer for a month and have only used the Lulzbot filaments, HIPS to be exact. I was looking online at the filament on Amazon just to see what was getting good reviews and might be a bit cheaper. I wanted to try out some abs and found the IC3D brand on Amazon had good reviews. It's about 7 or 8 bucks cheaper than the Lulzbot brand too. But now looking at the roll that Brew4you posted, I'm wondering is it really worth it just to save a couple of bucks. The Lulzbot stuff comes from Pennsylvania and gets to my house in about two days. There is an Amazon distribution center here in Baltimore, so I can usually get stuff from them same day or next day. I may just have to try one roll and see how it works out.
Brew4You
Post by Brew4You » Sat Mar 21, 2015 7:01 pm
It's a tough call and I would say a wash. I paid $20 buck for that roll but only half of it is really useable so it would be like buying a $40 roll. Add in frustration and putting around and factoring in extra waste I would equate it the equivalent as costing me $50 for that roll.
Then again I can't always afford to spend $100+ a month on filament, especially if I'm just messing around and not selling any of the prints. I think--like anything in life--it's a balance. I eat the cost of trying different filaments because I'm still new to the industry and I'm generally a curious person.
