Service Bulletin: Thermistor Issue in Aerostruder and Dual Extruder v3 Tool Heads
Have questions? Want advice?
kcchen_00
Re: Service Bulletin: Thermistor Issue in Aerostruder and Dual Extruder v3 Tool Heads
Post by kcchen_00 » Fri Jun 01, 2018 9:27 pm
Marlin has a PID Autotune feature. Other tutorials REPRAP and Marlin.
Galadriel
Post by Galadriel » Mon Jun 04, 2018 1:11 pm
b-morgan wrote:
Fri Jun 01, 2018 5:42 pm
Galadriel wrote:
Thu May 31, 2018 7:20 am
We have actually optimized the PID settings for the Aerostruders more powerful fans. To have those new settings be enacted you have to first flash the firmware then through the console enter first M502 then M500 this will restore settings to default and save those settings allowing the new PID settings to be enabled
Would you be so kind as to give us the minimum version number of the firmware that contains these changes?
The new PID values were enacted in firmware version 1.1.5.70 that came with Cura 2.6.66. As long as you are using Cura 2.6.69 and the accompanying firmware of 1.1.5.71 then these values will be present in the software.
reveds69
Post by reveds69 » Tue Jun 19, 2018 7:20 am
Afternoon my Aerostruder fell into the serial number range denoted by sticker on back of tool head range.
Unfortunately I wasn't in the position to be able to arrange return of the head so........
I have replaced the thermistor and the wiring all the way upto the main loom plug with soldered joints I have the latest Cura LE 3 installed and the print head firmware updated through Cura and M coded as per installation instructions.
Problem is I still keep getting creeping temperatures what have I missed ? the replacement thermistor is a genuine E3D V6 thermistor.
Is this a firmware issue do I need to revert back to the last official Cura release 2.6.69 ? to get back on track ?
Thanks in advance
Brent.I
Post by Brent.I » Tue Jun 19, 2018 7:30 am
We have recently released Cura 3.2.21. Release notes on whats new can be found here: https://code.alephobjects.com/w/cura-lulzbot/
The Marlin included for all printers will be the latest stable upstream branch of 1.1.8.59 This is what we are currently recommending across all tool heads, and will be worth upgrading to. When installing the new Cura be sure to uninstall previous versions, and clear your cache afterwards. Operating specific instructions can be found here lulzbot.com/cura
reveds69
Post by reveds69 » Tue Jun 19, 2018 2:12 pm
Hi Brent many thanks for the reply as I mentioned I am running latest version of Cura LE 3 and as I had already swapped out all of the wiring and sensor with neat soldered joints at the loom connector and still having issue I could only guess that the issue I have is software / firmware related.
I just thought if I reverted back to the previous release to see if the problem went as this was originally a thermistor / wiring issue.
Brent.I
Post by Brent.I » Tue Jun 19, 2018 3:16 pm
Did you check all three connection points, or just the set at the loom? On the Aero thermistor, there will be three sets of pins you will want to check:
Thermistor Connections
If you replaced the thermistor with one that does not have the quick swap connector, this should not be required.
At what point in the print are you having temperature fluctuations?
reveds69
Post by reveds69 » Wed Jun 20, 2018 6:43 am
Hi Brent
The complete loom has been replaced from the new thermistor to the main tool head connector.
I am beginning to suspect that the error occurs when the filament cooling fan kicks in or the tool head is not close to the bed.
Just strikes me odd its only happened since the latest release of Cura ?
computer_panda
Post by computer_panda » Thu Sep 27, 2018 12:23 am
I had the same issues after i sent my toolheads back to lulzbot especially with petg, pla and other materials. I ordered silicone socks from matterhackers and so far my thermal runaway problem has not come back yet.
https://www.matterhackers.com/store/l/e ... k/MSW6K3SK
Bakunin
Post by Bakunin » Tue Oct 16, 2018 7:55 am
Thanks for the link.
tonyboutwell
Post by tonyboutwell » Sun Dec 23, 2018 10:34 am
Was ready to make the plunge and use my Christmas "funds" for a Dual Extruder v3... but all of the issues I have been seeing has given me pause. As of December 2018 - have all the issues been worked out? When I search youtube for users who are printing with it - I can only find 1 or two who showed an initial print and they have not posted anything else about it in 6 months. My usage will be exclusively to use water-soluble filament for support structures to help with my more complicated designs. My Lulzbot has run great from DAY 1 so I am little nervous about making an update that could make it less reliable.
New Taz 6 Owner
