TAZ 6 DualExtv2 - Heating Failed E0, PRINTER HALTED
Have questions? Want advice?
Jeff1961
Post by Jeff1961 » Wed Apr 11, 2018 3:11 pm
Hello. :)
We just purchased a new LulzBot TAZ 6 and are using it with a Dual Extruder v2.
We have done about 2 dozen test prints so far and at least 6 times now the job stops with this error on the display:
Heating Failed E0
PRINTER HALTED
Please Reset
At this point the job is ruined and the printer must be powered off and on again.
It always seems to be E0, the extruder at the back, not E1 in front.
Perhaps I should test jobs using just E1 to see if it occurs only in E0.
I've searched the forum for similar issues but do not see it discussed.
I'm wondering if this is common...or a sign of a bad extruder part. It is brand new and i've never used a LulzBot before, just MakerBot Rep2's for the past 3 years.
We had this issue with the initial ABS piece provided by LulzBot for the printer setup when unboxing, and with MakerBot PLA.
Thanks.
The attachment IMG_1664.JPG is no longer available
The attachment IMG_1665.JPG is no longer available
Jeff Heeney / Library Technician / University of Toronto Libraries / LulzBot TAZ 6 Dual Extruder v2
Jeff1961
Re: TAZ 6 DualExtv2 - Heating Failed E0, PRINTER HALTED
Post by Jeff1961 » Thu Apr 12, 2018 8:59 am
Just reposting an image that the forum deleted from my original post:
Jeff1961
Post by Jeff1961 » Thu Apr 12, 2018 9:00 am
bkirby
Post by bkirby » Sat Aug 18, 2018 4:24 pm
Did you ever find the cause of this problem? I have recently experienced this issue (3 times) with a brand new MOAR print head that was installed on a new printer (only printed two prints).
Jeff1961
Post by Jeff1961 » Mon Aug 20, 2018 8:11 am
No I haven't. We are awaiting an order of plastic to retest. I was using plastic that was too small in diameter and caused a clog...which we've since removed. However I need to wait until our new plastic arrives in order to do more tests for the heat issue. If it still occurs, we will remove the dual head and put on the original single head extruder and retest. Hopefully this will be done within the next two weeks.
Ehoff
Post by Ehoff » Thu Aug 23, 2018 8:13 am
It sounds like it could be a problem with the thermistor or heater cartridge. If you have access to a digital multimeter, we can check the resistance measurements on the tool head to see if the thermistor or heater cartridge is bad. With the printer turned off and unplugged, disconnect the hot end from the wiring harness and test hot end for the proper resistance. The smaller black and red wires coming from the hot end are for the thermistor and should read ~100k ohms at room temperature. The larger red wires are connected to the heater cartridge and should read ~20 ohms.
johe
Post by johe » Fri Jan 04, 2019 4:54 am
Same problem with my taz6 and dualextv2.
Did you ever find out what the problem was.
Jeff1961
Post by Jeff1961 » Sun Jan 06, 2019 11:09 am
Someone else in my large workplace had the same issue and said she found it as a "known issue" by Lulzbot, with no fix from them. (Taz 7 apparently has the issue resolved)
The basic workaround was something to do with an additional fan, and is only related to the Dual Extruder.
I'm not the person working directly on the problem so I do not have the specific details regarding the additional fan. However I found this which may be related:
viewtopic.php?t=4348
