Add Aerostruder to Kittaz/Taz4?
Have questions? Want advice?
tagscott
Post by tagscott » Tue Apr 17, 2018 3:58 pm
Can it be done easily? The aerostruder is listed as for the TAZ 5/6 and the Hexagon hot end is listed for the TAZ 4/5. I found a thread (viewtopic.php?t=2838) that lists the upgrades to move from a 4 to a 5 and all but one of the upgrades are about the hot end. I have already added the PEI sheet to mine and want to skip from the Hexagon straight to the Aero. If I add the extra wiring (https://www.lulzbot.com/store/parts/int ... arness-add) and replace the tool head harness (https://www.lulzbot.com/store/parts/lul ... ad-harness) would the Aero just be plug and play?
Galadriel
Re: Add Aerostruder to Kittaz/Taz4?
Post by Galadriel » Wed Apr 18, 2018 12:09 am
The upgrade that takes your printer from a Taz 4 to Taz 5 would enable you to jump straight to the Aerostruder toolhead. The only major difference between the two versions is the 5 came with an all metal hot end, PEI on the bed, internal wire harnesses to support the extra cooling fans for the all metal hot end, and a different connector for hot ends for ease of use. Once these updates have been made and you update the firmware to the Taz 5 you will essentially have a Taz 5 and be able to treat it as such moving forward so anything that is listed as compatible with the Taz 5 will be compatible with your printer.
