Hi, I am having some issues with the hot-end leaking when the printer is traversing from different print areas.
It is leaking from the extruder, not the fittings.
It is a dribble and isn’t a huge issue, but I’d rather it didn’t extrude any plastic when it isnt printing.
Do you have retraction turned on in Slic3r? If so, increase the amount of retraction in small steps to see if that will prevent the ooze. If I remember correctly, the new Lulzbot Slic3r profile I used is retracting 1.7mm.
