wipe nozzle failed, Printer paused, help needed.
Have questions? Want advice?
joshua_nano
Post by joshua_nano » Wed Oct 03, 2018 6:05 pm
My friend has a Taz 6, single extrude. Not used for a long time.
The printer shall have worked fine before. However, I got an error message (attached picture) during the first printing.
Before the printing, the printer tried to wipe the nozzle on the cushion at the left front corner (facing) for 3 times, then report wipe nozzle failed. The printing job was interrupted and I was asked to reset the printer.
The nozzle temperature was at 170c
Any instruction on how to solve the issue?
Thanks a lot!
Video will be uploaded if needed.
NBradshaw
Re: wipe nozzle failed, Printer paused, help needed.
Post by NBradshaw » Thu Oct 04, 2018 7:20 am
Did you watch and see which washer the tool head would get to before going back to the wiper pad to rewipe? Depending on which washer it gets to can mean different causes to your issue here.
joshua_nano
Post by joshua_nano » Fri Oct 05, 2018 8:14 am
Thanks.
Could you explain what does the washer means here? Sorry, I am new to this printer.
I will post a video later to help the debug.
Again thanks a lot!
joshua_nano
Post by joshua_nano » Fri Oct 05, 2018 12:21 pm
I cleaned the nozzle and the extraction shall be fine.
I uploaded a video here, please check
https://youtu.be/p0ctD7-uvCk
I just noticed that the printer actually reports the bed leveling failed before it stops to work. Could you provide some instructions on how to level it?
Also, I am not sure the following is normal
When it is turned on, the X, Y, Z positions are flashing with the question marks. Always need to home all the axis before it can be used. Please see the attached picture.
kmanley57
Post by kmanley57 » Fri Oct 05, 2018 12:29 pm
joshua_nano
Post by joshua_nano » Fri Oct 05, 2018 1:58 pm
