Connector pin removal woes
Replacing Aerostruder print head and this how-to is easy to follow:
https://ohai.lulzbot.com/project/mini-2-aerostruder-hotend-replacement/maintenance-repairs/
However, “Using the pin removal tool…”
(I don’t have this tool.)
Can someone point me to the specific pin removal tool OR
the aerostruder molex connector part number so I can identify which version to use on this connector?
The instructions link to:
https://www.molex.com/pdm_docs/ats/ATS-011030043.pdf)
But numerous tools are listed.
OR
More details on how to use “some sort of tool with a small point”?
Solved
watched:
made two “probes” out of .03" music wire (hammered flat, filed, rounded ends, removed burrs):
pliers used to poke around until felt probe slip in a short bit (one side of pin at a time) as shown in video.
A pick or sharp object usually works to push the pins/latches on the connectors…
I use upholstery pins.
https://www.amazon.com/Pack-Upholstery-Skewers-Pins-Upholsterers/dp/B07G5G56FW
I had the same problem. I flattened 2 paper clips and got the pins out. The next problem is getting the bearing out. For $125, they should have provided a new bearing. Per the instructions “A spare stepper motor shaft is a good tool to remove the bearing”. Sorry, I don’t have any spare stepper motors lying around. Anything that I have will likely damage the bearing.
I experienced this as well. We used bent staples and it was a huge pain. Finally bought a molex extraction tool was a life saver!
