Autodesk Inventor Files
mrgroark
Post by mrgroark » Tue Feb 14, 2017 10:01 am
I usually create my STL files in Autodesk Inventor. Whenever I do this in order to get the file the actual size I need to scale it up 10x. Does anyone know why this is happening and how I could fix it so I don't have to scale it up?
afrlmakerhub
Re: Autodesk Inventor Files
Post by afrlmakerhub » Fri Feb 17, 2017 7:34 am
I suggest going into the options when saving the STL and select the units to be mm from cm.
Here's some pics to help!
AFRL Maker Hub
piercet
Post by piercet » Fri Feb 17, 2017 10:22 am
Thats exactly what you are running into.
mrgroark
Post by mrgroark » Thu Feb 23, 2017 11:47 am
Thanks everyone that worked. I just needed to change it in the options menu from centimeters to millimeters
