I am using the 3.6.18 version of Cura for Lulzbot. I am having a hard time getting it to pause at a certain layer. None of the codes work that are loaded in the program. I used to use 21.04 and had a plugin to pause at layer. I could pause it a certain layer to change the filament, and it didn’t have a time limit set, I just changed the filament whenever I got to it, then resumed with a new color. Please help!!!
The Pause at Layer funciton is in your current version of Cura.
At the top of your window, cllick on Extensions --> Post Processing --> Modify G-code
Click on Add Script and select Pause at Layer or Height.
