Hi folks,
I’m running a Mini 1 with the Graphic Display. I use Cura 3.6 set the print preferences and then save and print using an SD card. I want to make a couple of changes to the Start and End gcodes in the machine settings. I don’t know if either are possible and would really appreciate any input.
- For the Start Code: I’d like to set the last step of the to display “name of the file” Printing…, instead of “Mini Printing…”
- For the End Code: The default code has the extruder cool off completely. I’d like to instead lower the extruder temp to the {material_wipe_temp} and keep that temperature. I tried a variety of commands to make this happen, but the extruder temp always clears to zero after the printer stops. Even if I add an M104 or M109 command at the very end of the code, the printer does not retain the temp like it does with the heated bed. Is there a way to keep the extruder head primed for the next print.
I used this website as a reference but couldn’t find what I needed. http://marlinfw.org/meta/gcode/
Below is the default Start/End Gcode for a Mini1(GLCD).
Thanks, for your help!
Tiz
START GCODE
;This G-Code has been generated specifically for the LulzBot Mini with standard extruder
M73 P0 ; clear GLCD progress bar
M75 ; Start GLCD Timer
G26 ; clear potential ‘probe fail’ condition
M107 ; disable fans
M420 S0 ; disable leveling matrix
G90 ; absolute positioning
M140 S{material_bed_temperature_layer_0} ; start bed heating up
G28 ; home all axes
G0 X0 Y187 Z156 F200 ; move away from endstops
M109 R{material_soften_temperature} ;
G1 E-30 F75 ; retract filament
M109 R{material_wipe_temperature} ; wait for extruder to reach wiping temp
G1 X45 Y173 F11520 ; move above wiper pad
G1 Z0 F1200 ; push nozzle into wiper
G1 X42 Y173 Z-.5 F4000 ; wiping
G1 X52 Y171 Z-.5 F4000 ; wiping
G1 X42 Y173 Z0 F4000 ; wiping
G1 X52 Y171 F4000 ; wiping
G1 X42 Y173 F4000 ; wiping
G1 X57 Y173 F4000 ; wiping
G1 X77 Y171 F4000 ; wiping
G1 X87 Y171 F4000 ; wiping
G1 X77 Y173 F4000 ; wiping
G1 X97 Y171 F4000 ; wiping
G1 X107 Y173 F4000 ; wiping
G1 X112 Y171 Z-0.5 F1000 ; wiping
G1 Z10 ; raise extruder
G28 X0 Y0 ; home X and Y
G0 X0 Y187 F200 ; move away from endstops
M109 R{material_probe_temperature} ; wait for extruder to reach probe temp
M204 S300 ; set probing acceleration
G29 ; start auto-leveling sequence
M420 S1 ; enable leveling matrix
M425 Z ; use measured Z backlash for compensation
M425 Z F0 ; turn off measured Z backlash compensation. (if activated in the quality settings, this command will automatically be ignored)
M204 S2000 ; restore standard acceleration
G28 X0 Y0 ; re-home to account for build variance of earlier mini builds
G0 Y152 F4000 ; move in front of wiper pad
G4 S1 ; pause
M400 ; wait for moves to finish
M117 Heating… ; progress indicator message on LCD
M109 R{material_print_temperature_layer_0} ; wait for extruder to reach printing temp
M190 R{material_bed_temperature_layer_0} ; wait for bed to reach printing temp
G1 Z2 E0 F75 ; prime tiny bit of filament into the nozzle
M117 Mini Printing… ; progress indicator message on LCD
END GCODE
M140 S{material_part_removal_temperature} ; start bed cooling
M104 S0 ; disable hotend
[/color]M107 ; disable fans
G92 E5 ; set extruder to 5mm for retract on print end
M117 Cooling please wait ; progress indicator message on LCD
G1 X5 Y5 Z158 E0 F10000 ; move to cooling position
G1 E5 ; re-prime extruder
M190 R{material_part_removal_temperature} ; wait for bed to cool down to removal temp
M77 ; Stop GLCD Timer
G1 X145 F1000 ; move extruder out of the way
G1 Y175 F1000 ; present finished print
M140 S{material_keep_part_removal_temperature_t}; keep temperature or cool down
M84 ; disable steppers
M117 Print Complete. ; print complete message
