Hi all, first post:
I tried searching for this question, but I didn’t come across it, so hopefully I’m not repeating an existing topic.
I have not received my TAZ yet, but I have started modeling/downloading to get prepared for when it arrives. I am using Sketchup 2013 because I have some experience with the program from some years ago. My issue is that imports from STL format are not coming into the program at the correct size. I have tried to import with the template set to mm, m, and feet and inches, but in all cases they are scaled roughly 25 times larger. I think it may have to do with the conversion from mm to in being 25.4, but why would this happen even when the template is set to mm?
Even when I scale it down in Sketchup, then export it to a STL format, then re-import it into Sketchup, it is still the wrong size.
I appreciate the help. Also does anyone has any programs that they suggest using, and why?
