Cura modes: Quickprint vs Full settings (Expert mode)
reddot
Post by reddot » Tue Sep 13, 2016 9:56 am
Hey there,
Is there info on what settings in expert / full settings mode map to the high detail, high speed, and standard settings in Quickprint?
Thanks.
Todd
Brent.I
Re: Cura modes: Quickprint vs Full settings (Expert mode)
Post by Brent.I » Tue Sep 13, 2016 11:11 am
Download our latest version of Cura here: lulzbot.com/cura
While still in quick print mode, select your desired profile.
When switching to full settings be sure to click "yes" when prompted to transfer settings.
All of the settings will correspond with the quickprint profile you selected. These all interact in with each other, so be sure to stick to one change at a time (when first starting) and see how it goes.
For a full rundown of the settings within Cura you can find all the user manuals here: https://www.lulzbot.com/content/downloads
reddot
Post by reddot » Tue Sep 13, 2016 4:54 pm
Thanks Brent!
myeager
Post by myeager » Tue Sep 13, 2016 5:48 pm
I'm a little unsure that this works. When I try this, the print speed is the same in the full settings mode whether I select Standard or High Speed (50 mm/sec) in Quick mode. I expected the print speed to be faster in High Speed, but if the settings are carrying over from Quick mode, the print speed is the same for both.
PdxSteve
Post by PdxSteve » Wed Sep 14, 2016 12:23 am
Are you looking at the Basic or Advanced tab? The basic tab is the default speed and will be used if one of the advanced settings (there are a few) is not filled in, and most of those should be different.
kmanley57
Post by kmanley57 » Wed Sep 14, 2016 6:34 am
Also remember the speed is more based on the layer height for those profiles and not the head movement speed.
