starting @ a higher Z plane for multi-color print
Hey folks, I have a TAZ 6 and run the supplied CURA software as my slicer. I want to create a two color layered print. I only print via SD card so I can not simply pause the print a specific height to allow me to change the filament. So what I want to do is load the items into CURA and then do a stop at certain Z height. Then I want to create a second G-code that starts at a certain Z height.
I understand that I can do this in Simplify3D but I was hoping that within the advanced settings there would be a starting z height adjustment setting.
I appreciate all the help you can give in advance.
Jon
Have you read my recent post?
https://forum.lulzbot.com/t/cura-20-pause-at-layer-plugin/4028/1
