TAZ Slic3r profiles
mousera
Re: TAZ Slic3r profiles
Post by mousera » Tue Nov 18, 2014 2:08 pm
gghouck
Post by gghouck » Tue Nov 18, 2014 8:07 pm
mousera
Post by mousera » Thu Nov 20, 2014 3:32 pm
gghouck wrote:Here's a couple of profiles that work decent for a .50 nozzle.
http://home.gci.net/~gghouck/Medium_ABS ... 1layer.ini
http://home.gci.net/~gghouck/Medium_ABS ... 2layer.ini
Appreciate the link but my problem with this is that Lulzbot is giving its customers a bad profile on their own website. It seems like it is a very minor fix to change the fill to 20-25%. I think it is bad for the company to not fix this.
Orias
Post by Orias » Fri Nov 21, 2014 9:32 am
We provide the Slic3r profiles as a starting point for our customers. Please keep in mind that most of our users will tweak each slicing profile to suit their particular model, as there are always ways to improve your print, model by model, slice by slice.
The infill density is a variable that can be changed print by print. A higher infill density will help with models with small structures. The medium profile is set to be used as a profile that will work for almost all models and all users.
The two profiles you linked do not have any hot end or bed temperatures specified in the configuration file. Make sure it's imported correctly. Your temperature settings under the filament tab will read "0" if you imported successfully. If you are using the Fine ABS profile, we have different temperatures specified in that particular profile for improved bridging/overhangs to help balance out the thinner layers and increased layer time.
mousera
Post by mousera » Fri Nov 21, 2014 11:20 am
Orias wrote:We provide the Slic3r profiles as a starting point for our customers. Please keep in mind that most of our users will tweak each slicing profile to suit their particular model, as there are always ways to improve your print, model by model, slice by slice.
So you are saying that the 50% infill in the medium profile on the Lulzbot is intentional?
gghouck
Post by gghouck » Sun Nov 23, 2014 7:46 pm
What they're saying is that the 50% infill is adjustable.....
I personally don't find 20-25% to be optimum, wouldn't really call that a "fix".
ReddFoxx
Post by ReddFoxx » Tue Nov 25, 2014 7:43 am
Can lulzbot supply (or anyone else) a profile for dual extruder, with a GOOD profile for PVA support material?
mdanbe
Post by mdanbe » Tue Dec 16, 2014 10:53 pm
I've been following these instructions to load a new profile:
"To view the contents of each profile simply click on them. Your browser should display the contents. To save the profile right click on the profile you would like and select "Save as". Once saved to a memorable location, load the configuration file in Slic3r by selecting File > Import Config."
After choosing import config I select the ini. file and click open and Slic3r crashes every time.
Any ideas as to what is going on?
Thank you.
mdanbe
Post by mdanbe » Tue Dec 16, 2014 11:27 pm
Also, I've tried it on multiple version of slic3r the latest of which is: slic3r-mswin-x86-1-1-7-stable (1)
gghouck
Post by gghouck » Wed Dec 17, 2014 1:10 am
Try right-clicking the link to save-as then load that file the same way.
Can you post a link to the file you saved? Perhaps something is getting added or taken away.
