Controlling Support Print Speed with Cura (Dual Extruder)
Hi,
I’m printing with a TAZ 5, V2 Dual Extruder using PLA and PVA support.
Is there a way to (in Cura) set the speed for the PLA extruder and separate speeds for the support material in the PVA extruder?
The PLA prints well at higher speeds than the PVA can handle.
Can I set print speeds to the extruders individually?
OR
Can I set different print speeds for the support material?
Does anyone know if “support material” falls into a certain category on the “advance print tab” in cura? (i.e. Bottom Layer, Infill, Outer Shell, Inner Shell, etc)?
I tried searching about this and nothing relevant came up.
Thank you all in advanced!
Best,
Jack
