I recently got my print head back from customer service - repair/replace FTW!
I set it up (realized I plugged the pins in backwards… ) and got it running. I tried to import the profile and when I went to print the print temp and bed temp only got to 210 and 61 respectively. The profile was set to 230/85. Everything appeared to be okay until the filament stuck to itself and the print job and would not go anywhere. There was a nice clump of material and I canceled the print, cleaned everything up, cleared the CURA job and started over. I manually set the temp to match the setting in the profile I thought I imported, using the control panel and I’m starting up again. Hopefully the print will work this time.
Did I just have an old setting overwriting the profile I loaded?
