Hello,
I’m looking for high detail profile with the DUAL extruder v2 for TAZ 6.
On this page:
https://www.lulzbot.com/taz-6-cura-profiles
there are only profiles for standard print, not for high detail. Standard print profile works, but the resolution is not good for me when I use two different filaments (Ngen and PVA), and every test with higher resolution (in expert mode) I did fail.
So, if someone has profile for high detail for the DUAL extruder v2, it would be great.
I’m using Ngen (extruder 0) and PVA for support (extruder 1).
Thank you.
chrispi
