Firmware updating on OS X machine with Lulzbot Cura
Hi,
I have a Lulzbot Mini which has been working like a champ for a while, printing via Ocotoprint. I received a LulzBot Mini Single Extruder Tool Head v2.1 today. As I’ve read, I can’t use it until I use Lulzbot Cura to update the firmware for the new toolhead.
I’m on a 2017 Macbook Pro and the current Lulzbot Cura Beta can’t see the printer. Digging around in the forums here a bit, this looks like this is a problem with OS X 10.12 and 10.11 (?). So, my question is, how am I supposed to update my firmware to use it with my newly installed tool head if Lulzbot Cura on OS X 10.12 can’t even talk to the printer. I don’t have any ancient (pre-10.11) Macs laying around, or Windows machines. What are my options now to get my (now) non-functional Lulzbot Mini to work? The only “port” displayed in the Lulzbot Mini “Machine Settings” in the manage printers option is ‘0’.
Oh, and the Arduino IDE on this mac can see and talk to the printer over the serial monitor just fine. The printer is at /dev/cu.usbmodem1451 at 115200 baud. I see clear Marlin output there.
start
echo:Marlin1.0.2
echo: Last Updated: Mar 3 2016 14:48:01 | Author: (none, default config)
Compiled: Mar 3 2016
echo: Free Memory: 5132 PlannerBufferBytes: 1232
echo:Hardcoded Default Settings Loaded
echo:Steps per unit:
echo: M92 X100.50 Y100.50 Z1600.00 E833.00
echo:Maximum feedrates (mm/s):
echo: M203 X800.00 Y800.00 Z8.00 E40.00
echo:Maximum Acceleration (mm/s2):
echo: M201 X9000 Y9000 Z100 E1000
echo:Acceleration: S=acceleration, T=retract acceleration
echo: M204 S2000.00 T3000.00
echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
echo: M205 S0.00 T0.00 B20000 X12.00 Z0.40 E10.00
echo:Home offset (mm):
echo: M206 X0.00 Y0.00 Z0.00
echo:PID settings:
echo: M301 P28.79 I1.91 D108.51
So how do I upload current firmware to this printer and tell it that I have this specific toolhead now?
Further update:
The current version of standard Cura (2.6.2) can see the printer just fine if I connect Cura to it. So this is a Lulzbot Cura issue, not a Cura (in general) issue.
Of course, Cura 2.6.2 has no listing for Lulzbot machines in it and my only firmware option is to upload a custom firmware (I assume the only Taz Mini file available at www.lulzbot.com/content/downloads ) but if I did that, I’d still have no way to set the new toolhead so I’d be where I am right now.
