Taz 4 settings
Posted: Wed Jan 10, 2018 12:37 am
by stephen.bornstein
I have a current version of cura lulzbot edition (2.6.63) and wandering whether to select a newer Taz printer or custom printer and import G code for configuring the Taz 4?
If custom on Taz 4 what G code should I be using for printing and profiles for the materials should be selected?
Thanks,
Stephen
Re: Taz 4 settings
Posted: Sat Jan 13, 2018 10:48 pm
by Galadriel
Taz 4 is not compatible with the newest version of Cura, you will want to stick with Legacy Cura at least for now. It is possible that sometime in the future there will be a way to import the firmware for a Taz 4 into Cura LE but for right now they changed the file type from .Ini and there isn't a simple way to convert it into the new file type. You would essentially have to build the machine settings from scratch by referencing the old settings in Cura Legacy.
Re: Taz 4 settings
Posted: Mon Sep 24, 2018 11:14 am
by wyostargazer
Galadriel, do you have a legacy Cura version that you prefer when using elder printers?
Re: Taz 4 settings
Posted: Tue Sep 25, 2018 7:38 am
by Galadriel
The most current version of Legacy Cura is 21.08, this is going to be the best option if you are working with a Taz 4. The Taz 3 and older aren't immediately compatible with Cura and for those it is probably best to stick with the original slicing software recommended which would most likely have been either Slic3r or Printrun.
Re: Taz 4 settings
Posted: Thu Oct 25, 2018 2:48 pm
by gehrig44
Does anyone know where to download the legazy version of Cura that works with Taz 4? Assuming it is still 21.08.
Re: Taz 4 settings
Posted: Thu Oct 25, 2018 2:59 pm
by Brent.I
21.08 would be our last release of Cura Legacy. You can find the download for it here: http://download.lulzbot.com/Software/Cu ... ura_21.08/
