Yeah I am trying! So now I am having an issue with the heater nozzle temperature. I have an E3D volcano kit. I have a PT100 thermistor and I changed the pin.h to this:
#define HEATER_0_PIN 9
#define TEMP_0_PIN 93 //0
I also changed the configuration.h:
//=============================Thermal Settings ============================
//–NORMAL IS 4.7kohm PULLUP!-- 1kohm pullup can be used on hotend sensor, using correct resistor and table
//// Temperature sensor settings:
// -2 is thermocouple with MAX6675 (only for sensor 0)
// -1 is thermocouple with AD595
// 0 is not used
// 1 is 100k thermistor - best choice for EPCOS 100k (4.7k pullup)
// 2 is 200k thermistor - ATC Semitec 204GT-2 (4.7k pullup)
// 3 is mendel-parts thermistor (4.7k pullup)
// 4 is 10k thermistor !! do not use it for a hotend. It gives bad resolution at high temp. !!
// 5 is 100K thermistor - ATC Semitec 104GT-2 (Used in ParCan & J-Head) (4.7k pullup)
// 6 is 100k EPCOS - Not as accurate as table 1 (created using a fluke thermocouple) (4.7k pullup)
// 7 is 100k Honeywell thermistor 135-104LAG-J01 (4.7k pullup)
// 71 is 100k Honeywell thermistor 135-104LAF-J01 (4.7k pullup)
// 8 is 100k 0603 SMD Vishay NTCS0603E3104FXT (4.7k pullup)
// 9 is 100k GE Sensing AL03006-58.2K-97-G1 (4.7k pullup)
// 10 is 100k RS thermistor 198-961 (4.7k pullup)
// 60 is 100k Maker’s Tool Works Kapton Bed Thermister
// 1k ohm pullup tables - This is not normal, you would have to have changed out your 4.7k for 1k
// (but gives greater accuracy and more stable PID)
// 51 is 100k thermistor - EPCOS (1k pullup)
// 52 is 200k thermistor - ATC Semitec 204GT-2 (1k pullup)
// 55 is 100k thermistor - ATC Semitec 104GT-2 (Used in ParCan & J-Head) (1k pullup)
#define TEMP_SENSOR_0 20 //5 to 20
//~ #define TEMP_SENSOR_1 5
//~ #define TEMP_SENSOR_2 0
#define TEMP_SENSOR_BED 7
and I have the thermistortables.h:
#if (THERMISTORHEATER_0 == 20) || (THERMISTORHEATER_1 == 20) || (THERMISTORHEATER_2 == 20) || (THERMISTORBED == 20) // PT100 with INA826 amp on Ultimaker v2.0 electronics
/* The PT100 in the Ultimaker v2.0 electronics has a high sample value for a high temperature.
This does not match the normal thermistor behaviour so we need to set the following defines */
define HEATER_0_RAW_HI_TEMP 16383
define HEATER_0_RAW_LO_TEMP 0
#endif
#if (THERMISTORHEATER_1 == 20)
define HEATER_1_RAW_HI_TEMP 16383
define HEATER_1_RAW_LO_TEMP 0
#endif
#if (THERMISTORHEATER_2 == 20)
define HEATER_2_RAW_HI_TEMP 16383
define HEATER_2_RAW_LO_TEMP 0
#endif
#if (THERMISTORBED == 20)
define HEATER_BED_RAW_HI_TEMP 16383
define HEATER_BED_RAW_LO_TEMP 0
#endif
const short temptable_20[][2] PROGMEM = {
{ 0OVERSAMPLENR , 0 },
{ 227OVERSAMPLENR , 1 },
{ 236OVERSAMPLENR , 10 },
{ 245OVERSAMPLENR , 20 },
{ 253OVERSAMPLENR , 30 },
{ 262OVERSAMPLENR , 40 },
{ 270OVERSAMPLENR , 50 },
{ 279OVERSAMPLENR , 60 },
{ 287OVERSAMPLENR , 70 },
{ 295OVERSAMPLENR , 80 },
{ 304OVERSAMPLENR , 90 },
{ 312OVERSAMPLENR , 100 },
{ 320OVERSAMPLENR , 110 },
{ 329OVERSAMPLENR , 120 },
{ 337OVERSAMPLENR , 130 },
{ 345OVERSAMPLENR , 140 },
{ 353OVERSAMPLENR , 150 },
{ 361OVERSAMPLENR , 160 },
{ 369OVERSAMPLENR , 170 },
{ 377OVERSAMPLENR , 180 },
{ 385OVERSAMPLENR , 190 },
{ 393OVERSAMPLENR , 200 },
{ 401OVERSAMPLENR , 210 },
{ 409OVERSAMPLENR , 220 },
{ 417OVERSAMPLENR , 230 },
{ 424OVERSAMPLENR , 240 },
{ 432OVERSAMPLENR , 250 },
{ 440OVERSAMPLENR , 260 },
{ 447OVERSAMPLENR , 270 },
{ 455OVERSAMPLENR , 280 },
{ 463OVERSAMPLENR , 290 },
{ 470OVERSAMPLENR , 300 },
{ 478OVERSAMPLENR , 310 },
{ 485OVERSAMPLENR , 320 },
{ 493OVERSAMPLENR , 330 },
{ 500OVERSAMPLENR , 340 },
{ 507OVERSAMPLENR , 350 },
{ 515OVERSAMPLENR , 360 },
{ 522OVERSAMPLENR , 370 },
{ 529OVERSAMPLENR , 380 },
{ 537OVERSAMPLENR , 390 },
{ 544OVERSAMPLENR , 400 },
{ 614OVERSAMPLENR , 500 },
{ 681OVERSAMPLENR , 600 },
{ 744OVERSAMPLENR , 700 },
{ 805OVERSAMPLENR , 800 },
{ 862OVERSAMPLENR , 900 },
{ 917OVERSAMPLENR , 1000 },
{ 968*OVERSAMPLENR , 1100 }
#endif
Did I miss anything?
Again, I can’t stress how new I am to this.
So right now as is when I run and upload the Marlin I get a Mintemp error. I don’t know if my PT100 thermistor is broken. I also have a some other thermistors that have a blue wire and copper cylinder. I am not too sure if those are also PT100 thermistors.
Again, thanks. Any help, helps!
