Cura LE 2.6.66 firmware flash vs OctoPrint
John Mc
Post by John Mc » Wed Jan 31, 2018 12:41 pm
I've been delaying upgrading to Cura 2.6.66 due to the warning about needing to flash the firmware, and that once flashed, STLs sliced under previous versions will not work.
My problem is that I use my printer in a mixed environment: At home, I slice in Cura on my Mac Laptop, and send the gcode to my Lulzbot Mini (either directly, or via OctoPrint).
I also volunteer in an elementary school where we do various projects using my 3D printer. The laptops which the classroom has access to are ancient and won't run even moderately demanding programs (we do our design work online in TinkerCad). Due to both the limitation of the available equipment and the logistics of managing a classroom full of kids, we've been using OctoPrint to control the Mini and do our slicing. It has worked out very well for us. The kids' designs tend not to be extremely complex, so slicing is quick on the Pi. Plus they get a kick out of using the Pi for something like this.
OctoPrint's slicer is based on Ultimaker Cura 15.04.x, both that and the older versions of Cura I use can deal with the same firmware in the LB Mini. I'm concerned that if I upgrade my home system to 2.6.66, I won't be able to slice with OctoPrint at the school anymore.
I'm not looking forward to continually reflashing my firmware every time the printer moves back and forth.
Any thoughts on this? (and yes, I know... Ideally the OctoPrint folks would upgrade the version of the Cura engine they are using, but the main developer does not have time. I'm hoping someone does take on the task of making a new Cura plugin for OctoPrint.
robajohn
Re: Cura LE 2.6.66 firmware flash vs OctoPrint
Post by robajohn » Wed Jan 31, 2018 1:26 pm
Well it’s a late answer but for what it is worth I did not know you had to update your firmware to use 2.6. I just installed 2.6 and started using it.
Of course, not flashing the firmware is maybe why I don’t get the clean removing support structures now as I did with Cura 21?
EDIT-- Now you made me go and violate all my core beliefes and go read the intructions! I found this line...
"We recommend using the latest firmware included within Cura LulzBot Edition to maximize long-term compatibility."
Recommend != required.
Rob
John Mc
Post by John Mc » Wed Jan 31, 2018 1:37 pm
Apparently, earlier versions of 2.6.xx did not have this warning. I believe it just showed up with 2.6.66. Scroll down the Cura LulzBot Edition page to the "Download, Installation and Removal instructions, and see the note there:
Cura LulzBot Edition version 2.6.66 contains firmware standardized for use with all LulzBot Mini 3D Printers, and contains important bug fixes. However, once your firmware has been updated to 1.1.5.70, GCode files sliced with earlier versions of Cura LE will no longer be compatible and will have to be re-sliced using the latest version of Cura LE.
It's not really an issue unless you have a need to go back and forth between versions (as you do if some of your slicing is done in the version of Cura included in OctoPrint).
robajohn
Post by robajohn » Wed Jan 31, 2018 2:28 pm
Sometimes my attempts at humor fail mightily. In case there was any doubt, I was making fun of ME for not reading the instructions on 2.6 before I installed and started using it.
Brent.I
Post by Brent.I » Wed Jan 31, 2018 3:14 pm
Just a note with the octoprint issue. We have the communication issue sorted (from all received reports) over Octoprint with the Marlin 1.1.5.71 firmware. This firmware will be included in the Cura LulzBot Edition 2.6.68 build. We are currently running through testing to ensure nothing broke with the revs, but if you want to take a look it can be found here: http://devel.lulzbot.com/software/Cura2/
If you would like to run Cura LE with older FW (not recommended) after launching Cura LE go to Preferences > Configure Cura. Scroll to the bottom, and select "allow connection to wrong machines." This will prevent requiring the FW update in order to connect.
John Mc
Post by John Mc » Wed Jan 31, 2018 3:32 pm
Brent - I'm not sure what that means for me. Does having "the communication issue sorted (from all received reports) over Octoprint with the Marlin 1.1.5.71 firmware" mean that if I upgrade to version 2.6.68 and install that firmware, I will be able to send Gcode generated by older versions of Cura to my printer? If that's the case, I'll just wait for 2.6.68 to upgrade.
I'm mainly concerned that if I upgrade and install the new firmware, I still need to be able to slice in OctoPrint some of the time and send the resulting Gcode to my LB Mini (which if upgraded would have the new firmware).
Brent.I
Post by Brent.I » Fri Feb 02, 2018 11:19 am
My apologies, I thought you were referring to a communication issue reported here: https://code.alephobjects.com/T1598
As for the old Gcode no longer being compatible, it is due to a coordinate shift in Marlin. We had reported issues of endstop interference, causing probing and first layer issues. In order to prevent that endstop contact, we now home to a different position. This will shift the coordinate plane slightly, and can cause your nozzle to hit either the wiping pad or corner pads when using old gcode. In Cura LE, we have modified the start gcode to reflect this change.
If you would like to verify if your old gcode works, we highly recommend being present to watch the probing sequence and first layer being put down. If anything appears to be off, or interference is about to happen turn off the printer. Once you verify a specific gcode file, you can be confident it will work the same way in the future.
John Mc
Post by John Mc » Fri Feb 02, 2018 12:20 pm
OK. So let me verify that I am following this correctly:
If I upgrade to Cura LE 2.6.66 and flash the firmware to the current version, I may have problems when I try to slice using the version of Cura that is bundled with OctoPrint and then print on my LB mini.
OctoPrint relies on slicing profiles (.ini files) imported from a desktop version of Cura which must be based on Ultimaker Cura 15.04.x or older. In my case I've been using Cura LE 21.08, which has been working fine in my application (and is based on Ultimaker Cura 15.02.01, if I read the release notes correctly.) These profiles will have the start code which came with Cura LE 21.08, so will not work with my Mini if it's flashed to the new firmware, due to the coordinate shift you mentioned.
So is making older versions of Cura work with the new firmware, is it just a matter of changing the start Gcode? If so, is there a place in the newer Cura LE versions where I can copy that start code and paste it into my old Lulzbot Cura 21.08? That way, any Profiles I save (export) as .ini files from Cura LE 21.08 could be imported into OctoPrint's Cura slicer engine and still work with the new firmware. Unfortunately, while I can find the start gcode in Cura LE 21.08, I can't find it in Cura LE 2.6.66. If cut and paste won't work, are there changes I can just manually make to the Start Gcode in Cura LE 21.08 (I'm guessing these will have to be made individually in every slicing profile I export, rather than a change it once and I'm done sort of thing?)
I'd appreciate any help anyone can give in what I need to do to make the older version of Cura LE work with the new firmware. If I can't figure this out, it's going to slow our workflow in the elementary school where I volunteer down to a crawl.
ScottW
Post by ScottW » Fri Feb 02, 2018 1:33 pm
John,
Correct, the main issue is getting the start Gcode right. There were a bunch of problems with leveling, caused by how the newer firmware (1.1.5.xx) handles endstops, homing, and the leveling matrix. The start gcode was changed to avoid any movements on one axis while an endstop was triggered on another axis. Related issues led to changing X_Min from 0 to -3 (also changes X_Max by -3), and changing Y_Min/Max positions by 1. In some cases, the probing sequence caused a shifting of coordinates, so an extra homing operation for XY was needed after the G29 probing.
You should be ok with new firmware... As long as you incorporate changes from the new start scripts found in the version of Cura released with that firmware. Comparing the old (Cura 21) and new (Cura 2.6.66) start scripts, you'll see small changes to X and Y coordinates, deliberate small moves away from the endstops after homing, an additional homing of XY after G29, and a few other tiny changes.
That means the Octoprint Cura plugin profiles need to be updated if using that plugin for slicing, so it adds the correct start gcode. I don't use that plugin, so not sure exactly how to do that... But I think the right approach would be to edit/test the new scripts as part of a profiles in Cura21, then export those profiles and import them to the Cura Plugin on Octoprint just as you suggested.
In Cura2, you can find the start/end gcode under Settings, Printer, Manage Printers, Machine Settings (after clicking Machine Settings, expand the window -- it opens too small to see the gcode fields). Note that there are changes to the "placeholder variables" for temperatures and such, so when copying/pasting to Cura21 you will need to change those.
Only other issue I'm aware of... There are new communication features in 1.1.5.xx which are not supported by Cura21. Not sure if that is a problem or not, as I haven't tested it. But that's not a concern if your connection to the printer is via Octoprint.
Hope that helps...
John Mc
Post by John Mc » Fri Feb 02, 2018 2:39 pm
Thanks, Scott. That's very helpful.
I'll probably take a look at that over the weekend. Hopefully the changes will be obvious to someone with limited programming experience (self-taught BASIC in the mid 1970s, one Pascal night class in the early 80s - it's been a while).
This might still be an issue, since OctoPrint uses an old version of Cura? Or maybe not, since the communications with the printer in OctoPrint are not handled through the Cura engine?
