I am using Cura 2.6.69 and I am printing via USB with a Taz 6. I am trying to print, but I keep getting a message saying “Scanning for available serial ports for printers,” and nothing changes. Do I need to change something specific?
Usually if Cura is continuously scanning for your printer it is an issue with the Baudrate or the Serial Port being used. The correct Baudrate is 250000. Next the serial port should be set to auto, but check the drop down and see what shows up. Then unplug the printer and check the drop down again, one of the listings should be gone, go ahead and plug the printer back in and set the serial port to the listing that disappeared.
