Hi all,
every 3rd to 4th print seems to have an issue of the following two:
- Something happens with the path - the printer not following really the shape of the surface
I also noticed that this happened with two vasea at the same position
- The surface thickness changing - in the image you can see that the first layers are fine and then there is a break and layers are coarser
