Cura LE 3.2.21 How do you reset the material profiles
I’ve made some customization to a few material profiles which are now the saved settings. I can’t remember what some of the settings used to be and I’d like to be able to reset all the material profiles back to the original installed settings. How can I get them back to default settings?
We have the default profiles locked by default, so you should just need to select the High Detail, Standard, or High Speed. If there is still a star next to the quality name, go to the drop down and select “Discard current changes.”
Cheers,
