Running with S3D as I have had no luck at work with Cura 3.2.21 in getting a decent print on our TAZ 6 w. flexydually V2 print head. An example was that the two different extruder parts would randomly shift distance to each other on the build plate almost every time - it is like no one had actually used it before release.
Trying out 3.2.23 it is still not possible to get a decent print e.g. with Colorfab XT (Using Chromastrand inova-1800 profile) and Ninjaflex.
There seems to be massive over extrusion with recommended settings, and trying custom settings it is not clear what happens.
Changing custom settings and generating a g-code file (flowrate 95%, skirt lines 4, enable wipe tower, disable ooze shield), and then change to recommended settings for both filaments and generate a g-code file, the two files are identical in content. It looks like changing between custom and recommended settings does not start a new round of slicing. Is it really supposed be like that?
I guess the combinations of printers and tool heads are too many to test with a SW before release - are new Lulzbot Editions only testet with all the printer- toolhead combinations by users?
