Since the Marlin 1.1.9 release contains support for linear advance, I am curious if the new firmware does linear advance. I have heard it is enabled, but not activated. I am not sure what that means exactly.
So for the Mini 2 running 1.1.9, is the firmware doing linear advance?
Oh also, DO NOT run the new Cura 3.2.27 sliced gcode on a Mini 2 with the old 1.1.8.x firmware. It smashes the print head into the bed for the first layer.
In order to activate the linear advance, you will need to add an M900 K<float_value> to your start gcode. It is a little more advanced to get that tuned in for your specific filament, but the results look quite promising: http://marlinfw.org/docs/features/lin_advance.html
This is something we are working on, and hope to have a more point and click solution for customers in the future. You can follow along with our progress here: https://code.alephobjects.com/T2849
Thanks for the reply. Linear advance could be great, unfortunately, K is specific to filament used, so we’d need support for that for the Lulzbot supported filaments. Lots of work. However I thought the K value was related to filament expansion when heated or something, so maybe it will become something filament manufacturers print on the label along with temperature etc.
Indeed, it is going to be quite an undertaking with our hundreds of supported profiles. As we have not done much testing as of yet, the K factor may be dependent upon the different quality settings as well.
I surely hope so, it would save a lot of headaches!
