Issues with prints pausing after Cura and firmware update
bladerunner
Contact:
Post by bladerunner » Sun Sep 30, 2018 6:41 pm
Hey gang,
I have a Lulzbot Mini 1 and I recently upgraded my Cura software to the latest version (3.2.23) and the latest firmware and since then, randomly my prints will just pause in the middle of a print job. The print-head and the bed will still be at print temperature when it pauses so when I come back to check my print the extruder has melted the area around where it stopped printing. The only way I can get it to start printing again is to cancel the print job and start again. If I re-start the print job without moving the object or adding/removing another object when I restart it, it will stop at the same spot again. In other words, if I don't do something that forces the software to re-slice the object it will pause again in the same spot.
It doesn't do this every time and it doesn't do this one the same object I try to print. It seems totally random.
Needless to say this is frustrating and a waste of time and filament.
Anyone else experiencing this issue?
Thanks,
Michael
Michael
Lulzbot Mini
.5mm Dispenser Nozzle
bladerunner
Contact:
Re: Issues with prints pausing after Cura and firmware update
Post by bladerunner » Sun Sep 30, 2018 7:54 pm
Here's a an example....
These 2 prints were printed back to back. The one on the right was orientated left-to-right on the print bed and the print on the left was rotated 90 degrees and re-printed. As you can see, both stopped at different heights during the print.
`Michael
Michael
Lulzbot Mini
Tobotron
Post by Tobotron » Mon Oct 01, 2018 10:09 am
After nearly 9 months of flawless operation I upgraded cura and my firmware today and I too have the same issue , different heights in the prints . It’s happening on every print so far :-((
bladerunner
Contact:
Post by bladerunner » Mon Oct 01, 2018 7:43 pm
I upgraded Cura to the latest version (3.2.27), updated firmware, and continuing to have the same issue. I made sure to clear out the cache before upgrading.
Mine doesn't do it every time, but most times.
Any response from Lulzbot?
Michael
Lulzbot Mini
Tobotron
Post by Tobotron » Mon Oct 01, 2018 11:45 pm
No response as of yet, I cleared my cache and tried a rockyupis which ran fine, it got a bit late last night so I’ll try a few other models and see what happens
bladerunner
Contact:
Post by bladerunner » Tue Oct 02, 2018 12:40 am
I printed the Rockopus successfully as well, but tried printing something else directly after that and it paused again mid-print.
Michael
Lulzbot Mini
Tobotron
Post by Tobotron » Tue Oct 02, 2018 1:42 am
It’s quite frustrating , I’ll try a couple of other files tonight and report back
Tobotron
Post by Tobotron » Tue Oct 02, 2018 4:01 pm
Ok after some messing about this evening with different installs ect
I’ve now narrowed the problem down to this , if the screen saver or display sleep are activated (OS X) the printer stops nearly 2 minutes after and resumes when woken
Hdd sleep is set to ‘never’
If I disable screensaver and/or display sleep I appear to have no issues
Tobotron
Post by Tobotron » Tue Oct 02, 2018 4:03 pm
I’ve reverted to a previous version of cura (which runs more smoothly
Anyway) and tomorrow night I
May try reverting to the firmware
That came with he printer, which I seemed to have no issues with before the update
bladerunner
Contact:
Post by bladerunner » Mon Oct 08, 2018 7:54 am
Thanks for the update. I had also reverted back to the older version of Cura and have not had an issue since.
I'm hoping they get that fixed because eventually I'd like to be able to use the new software.
~Michael
Michael
Lulzbot Mini
