OctoPrint disconnects after printer asks to re-Wipe
InfiniteGinger
Post by InfiniteGinger » Mon Mar 04, 2019 4:37 pm
Since updating to latest Marlin firmware 1.1.9.34 my OctoPrint disconnects if the printer reports it needs to rewipe before printing. Octoprint will report a firmware error and disconnect. the printer will keep running the auto level sequence and after rewiping will touch all four corners and wait for more instructions from OctoPrint. Using Aerostruder tool head on Taz 6 Octoprint version latest 1.3.10...
Is anyone else experiencing this issue? Is there any work around? My bed is fine, washers clean, nozzle clean, nothing is loose, ground wire on bed is firm. I'm convinced this is firmware related as the bed levels itself the 2nd time nearly every time.
Also, since updating to new firmware, only one nozzle on my V3 will wipe on the pad, the right nozzle just grazes the outside edge.
Aha
Re: OctoPrint disconnects after printer asks to re-Wipe
Post by Aha » Mon Mar 04, 2019 9:23 pm
Thank you! I was meaning to post this myself yesterday and wasn't sure if I was going to get unlazy and post tonight, but I have exactly this problem!
I'm running the Taz 6 v3 head and I'm always getting this from every test I tried. EXTREMELY frustrating! I DID have 2 related workarounds that I'd been using until this weekend: first I deleted the autoleveling and moved it to a macro on the pi so I'd only level once and then run from there (this kills octolapse I just found out). Second there had been a workaround to increase the timeout before the pi considers the connection dead. It was working until this weekend on that macro, but doesn't seem to be working anymore.
I'm also getting this odd/useless new thing poping up telling me to click on the Taz to continue. Think that's interfering with some connections (it's actually cool if useful for filament changes and other stuff mid print if there's good documentation on how you code it).
This problem has led me to abandon cura and normal octoprint stuff until I can get some help like too! Can't understand how they can't work that out if they're working on octoprint too.
Thanks if anyone can work on this and help!
Aha
Post by Aha » Sun Mar 10, 2019 12:24 pm
Thought I'd follow up on this with my progress and with an email back from lulzbot. I'm still working on it, but this is where I'm at:
1. Tuning the autoleveling to hopefully not need rewipes (and also get a nicer level) - cleaning and fixing some connections through email directions that may help
2. Upping my timeout options on Octoprint - https://community.octoprint.org/t/octop ... meouts/227 is the centerpiece. (Note it's now under intervals and timeouts tab in the updated Octoprint). The re-wiping is still part of the G29 probe sequence command, and should be part of the "long running commands" subset.
I'm just going to up the max consecutive timeouts while printing/long running commands as well. Alternatively, you could just set all to 0 and it should get rid of this timeout problem. I'm not sure if that's a good idea, but if the printer is dropping out of communication from this timeout anyway, I'm not sure if there would be any difference between octoprint knowing it's timedout and it just pinging away forever. Maybe I've just talked myself into disabling timeout things and not worrying since I don't see a time that's ever going to be useful for me anyway.
thingmaker33
Post by thingmaker33 » Tue Mar 26, 2019 7:48 pm
Same problem as the OP.
I can tell just before it disconnects because by the time it gets to the 3rd disc to "tap", it stops short of the metal disc about 10mm, tries to tap but misses, by dropping below it... then disconnects.
I'm finding that after each print, I have to disconnect, and reconnect which forces the Taz 6 to restart. Then it prints. But if I print again right after one completes, it does the disconnect error.
wiggot
Post by wiggot » Sun May 12, 2019 10:00 pm
I know it's going to fail because I watch the extruder wipe, then move to the first pad and RAISE an additional cm. It doesn't even try to lower down to the first pad. It goes upwards, instead, like it's been sent a positive Z coordinate instead of a negative.
It happens with every subsequent print after a reset of the printer power and reconnect with Octoprint OR CURA Lulzbot Edition when connected by USB to my PC. I have power cycle, then auto-home, between every print job.
nopick
Post by nopick » Mon May 13, 2019 7:09 am
I had this problem as well. It is caused by older start gcode that doesn't deal with the bed leveling commands properly.
Here is the sample gcode Lulzbot sent me. I updated my start gcode to use the new commands and the problems went away.
Code: Select all
;This G-Code has been generated specifically for the LulzBot TAZ 6 with standard extruder
M73 P0 ; clear GLCD progress bar
M75 ; start GLCD timer
G26 ; clear potential 'probe fail' condition
M107 ; disable fans
M420 S0 ; disable previous leveling matrix
G90 ; absolute positioning
M140 S{material_bed_temperature} ; start bed heating up
M109 R{material_soften_temperature} ; soften filament before homing Z
G28 ; Home all axis
G1 E-30 F100 ; retract filament
M109 R{material_wipe_temperature} ; wait for extruder to reach wiping temp
M109 R{material_probe_temperature} ; wait for extruder to reach probe temp
G1 X-9 Y-9 ; move above first probe point
M204 S100 ; set probing acceleration
G29 ; start auto-leveling sequence
M420 S1 ; activate bed level matrix
M425 Z	    ; use measured Z backlash for compensation
M425 Z F0	    ; turn off measured Z backlash compensation. (if activated in the quality settings, this command will automatically be ignored)
M204 S500 ; restore standard acceleration
G1 X0 Y0 Z15 F5000 ; move up off last probe point
G4 S1 ; pause
M400 ; wait for moves to finish
M117 Heating... ; progress indicator message on LCD
M109 R{material_print_temperature_layer_0} ; wait for extruder to reach printing temp
M190 S{material_bed_temperature_layer_0} ; wait for bed to reach printing temp
G1 Z2 E0 F75 ; prime tiny bit of filament into the nozzle
M117 TAZ 6 Printing... ; progress indicator message on LCD
