Increase Max Wipe Temp in Cura (above 200 °C)
cg49me
Post by cg49me » Sat Mar 16, 2019 7:27 am
Is there any way to get Cura to let me increase the maximum wipe temperature above 200 °C? I've been printing with Taulman 910 nylon on my Taz 6 using the Aerostruder head, and I've been having to manually wipe the nozzle at 255 °C in order to get the auto-level probe sequence to succeed.
Related question - is there a way to adjust the re-wipe temperature? Whenever the probe fails following the initial wipe, it drops the nozzle temp to 170 °C for re-wipes.
khaoskosmos
Re: Increase Max Wipe Temp in Cura (above 200 °C)
Post by khaoskosmos » Wed Apr 03, 2019 8:00 am
I have the same problem and would like to see a response.
Taz 6
kmanley57
Post by kmanley57 » Thu Apr 04, 2019 6:17 am
The first one I believe is the material the wiper is made of will melt.
The second question if I remember from around a year ago posting is that that is coded into the firmware.
Both will require a change in the firmware settings and limits.
Strelok_401
Post by Strelok_401 » Tue Apr 30, 2019 1:24 pm
If the issues lies in the fusion temperature of the material the wiper is made of, then should that part be replaced as well? Do aftermarket alternatives exist, or should users try to jury-rig a part out of another material?
colincci
Post by colincci » Sun Oct 06, 2019 9:36 am
I am printing a lot of nylon filaments and I have the same problem. I have to do a manual clean before each print. The wiping procedure is useless for high temperature filaments @ 170C.
Does anybody know of a replacement wipe material that would be suitable at higher temperatures?
Orias
Post by Orias » Tue Oct 08, 2019 3:29 pm
This information is helpful and can be addressed in material profile updates in Cura LE.
Typically, we set the nozzle cleaning temperature to one lower than the extrusion range. Would you all mind posting your lowest cleaning temperatures you've used for specific nylon materials?
cg49me
Post by cg49me » Wed Oct 09, 2019 4:48 am
I actually have ended up using 200 °C for my nylon cleaning temp, but I've been using more aggressive cleaning material (high-grit sandpaper) in order to get a successful bed-leveling probe sequence.
Orias
Post by Orias » Wed Oct 09, 2019 9:39 am
Be careful with that, abrasive materials like sandpaper can erode your nozzle and change the geometry.
cg49me
Post by cg49me » Tue Oct 15, 2019 3:53 pm
Yeah, little bit of a trade-off... I'm using a fairly high grit (320) so hopefully I'm not causing damage too quickly. Nozzles are fairly cheap and easy enough to change out, though, so I feel the "risk"/wear is worth getting a perfect probe sequence and first layer.
