[SOLVED] New Mini2, need ocotopi settings please!
schotty
Post by schotty » Fri May 31, 2019 3:20 pm
Hello, new owner of a Mini2, and would like to get this working with OctoPi. Unfortunately, I am having difficulty getting a few settings sorted out.
What are the appropriate values for the x, y, z axes? I see that on the spec page I should use 300mm/sec for the extruder. Defaults are:
X = 6000 mm/sec
Y = 6000 mm/sec
Z = 200 mm/sec
E = 300 mm/sec
Andrew.
b-morgan
Re: New Mini2, need ocotopi settings please!
Post by b-morgan » Sat Jun 01, 2019 6:33 am
The "fine print" on this page:
This information is used for manual control via the "Control" tab. It does NOT influence already sliced files that you upload to OctoPrint!
I left mine (for the TAZ 6) alone and haven't had any problems. If you go to http://devel.lulzbot.com/software/Marlin/, open the folder for your version of firmware, and find the .config file for your printer / toolhead it should have the values you need. I'm guessing it should be:
#define DEFAULT_MAX_ACCELERATION {9000,9000,200,1000}
defuzz
Post by defuzz » Fri Jun 07, 2019 12:20 am
I'd recommend changing the E value to 150, otherwise the defaults have worked fine for me.
I experienced filament stripping when manually extruding in OctoPrint with the Mini 1 and the Hexagon hotend with it set to 300. 150 resolved the issue. I'm using an Aerostruder now (what the Mini 2 has) and have kept the setting. I'm printing TPU with it now and it has been extruding fine manually. I think 300 would be too fast.
schotty
Post by schotty » Sun Jun 09, 2019 4:15 pm
Thanks for the help guys, the printer is working perfectly via Cura -> OctoPrint!
