Link to the tutorial: https://www.lulzbot.com/learn/tutorials ... aintenance
The PEI film that is standard on the LulzBot printers has been tested by the advanced members of the LulzBot community and is the preferred print surface due to ease of use and excellent print adhesion without use of solvents or glues (when the surface has been cleaned and heated properly). With time, you will most likely have to replace the print surface if your printer sees a lot of use. However, if you maintain your PEI film with the tips outlined in this tutorial, you can maximize the life expectancy of your print surface.
