That's strange...
You could take a look in this: https://ohai.lulzbot.com/project/firmwa ... e-flashing.
Although, from what you're saying, if it was a miscommunication or miscompile issue, then you should get an error message from Arduino and nothing would have been uploaded. It seems to me that something in your code passes the Arduino tests and checks but it doesn't work with TAZ. Like some pins are conflicting on board.
TAZ6 Thermocouple with MAX6675 installation
Re: TAZ6 Thermocouple with MAX6675 installation
Thanks for replying
I fixed the upload problem. I watch this video and got the idea: https://www.youtube.com/watch?v=0pt_b2ZizQM
I uncommented this line to get the sounds from the button in the Configuration.h tab:
#define SPEAKER
and also this line:
#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
But know that I'm trying to make changes to the temp sensor 0 (-2, because it is a max6675) I get this error. I'm using a Taz 6.
MAX6675_SS (required for TEMP_SENSOR_0) not defined for this board.
I hope that someone that had the same problem could help me.
Thanks
#define SPEAKER
and also this line:
Thanks
