RUST on z-axis lead screws
A forum dedicated to those intrepid few, that have built their own TAZ 3D printers using our KITTAZ.
dustMason
Post by dustMason » Mon Mar 02, 2015 2:57 pm
I was away for about 3 weeks and just returned to find a serious amount of rust all over my z axis lead screws on both sides!
I only assembled my kittaz in December and printed a few things and already its out of commission :(. I never greased the machine and don't think I live in a particularly humid area (Oakland, CA). The machine is, however, exposed to the sun for several hours a day. I noticed that there is more rust on the side closest to the window. Maybe thats not helping?
Do I need to buy replacements already? Very sad. I guess I also need to pick up some lithium grease to prevent this from happening again?
Orias
Re: RUST on z-axis lead screws
Post by Orias » Mon Mar 02, 2015 4:55 pm
Lithium grease is recommended, typically every month. You may want to grease it, wipe the excess and run it up and down. You can probably run it up and down while wiping off the excess lubricant to clean the threading a bit.
dustMason
Post by dustMason » Mon Mar 02, 2015 6:10 pm
Do you think I can salvage the current rusty screws?
mhackney
Contact:
Post by mhackney » Mon Mar 02, 2015 6:46 pm
Sure. I've had this happen on my small Chinese mini mill and it does not affect performance at all. Clean them up as best you can. I'd use a tooth brush and some rust remover and protect everything with plastic wrap and rags. Careful with the rust remover, use a little and scrub with the brush. Once you've removed most of the rust, clean it up with moist rags and then let dry and treat with lithium grease.
Is there a preferred lithium grease or are they all about the same?
Sublime Layers - my blog on Musings and Experiments in 3D Printing Technology and Art
Start here:
A Strategy for Obtaining Great Prints
Strategies for Resolving Print Artifacts
The Eclectic Angler
dustMason
Post by dustMason » Mon Mar 02, 2015 7:41 pm
Thanks for the advice! I saw on another thread that Lulzbot HQ uses Lucas brand white lithium grease.
mhackney
Contact:
Post by mhackney » Mon Mar 02, 2015 8:40 pm
Cool, I have a tub of Lucas in my shop. Time to lube my screws.
Start here:
The Eclectic Angler
do-it-for-science-
Post by do-it-for-science- » Fri Apr 10, 2015 5:38 pm
I ended up using the wd-40 white lithium spray
open source, open heart,
Jeff Hunt,
Renewable Energy Engineering student OIT
