Latest Firmware for TAZ5 - advanced development version
billyd
Re: Latest Firmware for TAZ5 - advanced development version
Post by billyd » Thu Jan 05, 2017 6:38 pm
Here is the code updated for a Taz 5. Use at your own risk as I may have missed something when adjusting the .h files although everything seems to be working fine on my machine. Great in fact, best firmware yet imo.
I have incorporated the Prepare menu bug fix (that was unfortunately in this latest rcbugfix release) and the menu now works as it's supposed to. (Altered the ultralcd.cpp file code per github)
IMPORTANT! I am using a custom bed, and a custom hot end. So the PID values and the thermistor numbers will have to be altered for a stock Taz 5 in the configuration.h file before compiling and uploading to your printer. And of course you'll need to change esteps for your extruder, the K value (for LIN_Advance) and perhaps the default acceleration for your printer (I have it set to 900 for mine, I can go higher but this seems to produce the best prints for me on smaller parts. On bigger parts I can get away with 1100 or so). I also changed the PLA and ABS temperatures for my system, which you may want to change.
I am really happy with the print quality. Best firmware yet. However I have noticed if I stop a print midway from the LCD and then start another I get a thermal runaway error unless I shut the printer down.
Marlin-RCBugFix.zip
(1.44 MiB) Downloaded 80 times
Sebastian
Post by Sebastian » Fri Jan 06, 2017 3:52 am
8-)
billyd wrote:However I have noticed if I stop a print midway from the LCD and then start another I get a thermal runaway error unless I shut the printer down.
I guess stopping the print clears the target temperatures, starting a new one is setting it again and start heating from a still half-hot hot end? Then the settings for the thermal runaway check are too agressive, try to relax them a bit. They relaxed them already in RCBugFix in the past and it's now working with my stock TAZ 5 hotend but I also had this error in the past.
billyd
Post by billyd » Fri Jan 06, 2017 7:07 am
Sebastian wrote:8-)
Yes that's it exactly. I'll need to search for those values and change them. But the print quality is fantastic. I am using K=110 and ABS on an E3Dv6 extruder. Perfect. The only blob I get now is the very first line of a print job after a priming brim, when it begins the actual part I get a blob. But not one more after that for the entire print job! Yay! It may be something wrong in S3D though, maybe not putting in a retract command after the brim and before printing the actual part and then adding an unretract before printing the part causing the over extrusion.
Sebastian
Post by Sebastian » Fri Jan 06, 2017 8:15 am
I don't know how easy it is for you to read through the gcode. If you know the structure it's not that hard to go through it and see if the error is in the gcode file.
In any case, if you have a file that constantly creates a blob as you described it, I would be happy to get it. If it's a missing retract, I will see it. If it's not, and it happen only with LIN_ADVANCE enabled, it would be a perfect example to track this possible bug!
vitormhenrique
Post by vitormhenrique » Fri Jan 06, 2017 10:19 am
Hello Guys,
I started testing the firmware yesterday. Only LIN_ADVANCE enabled, no firmware retraction, is it worth it?
I basically use ABS, and it turned out that k arround 60 was the best value for me... check the pictures.
I'm also attaching the config files tuned for TAZ 5. I enabled the CUSTOM_BOOTSCREEN with the default lulzbot image ;)
I'm attaching the config files as well compiled hex, with and without bootloader.
If you are using a programer, make sure that you use the firmware with bootloader.
* I just noticed that I uploaded incorrect files will update tonight when I get back home....
Use at your own risk.
Vitor Henrique
Last edited by vitormhenrique on Mon Jan 09, 2017 10:34 am, edited 1 time in total.
billyd
Post by billyd » Fri Jan 06, 2017 11:00 am
I love firmware retract. You need to process your gcode file and swap out retract and unretract g1 moves with g10 and g11 respectively, unless your slicer supports firmware retract directly. Then just turn it on in the lcd panel. Works great.
Surprised by your K value... now I want to go back and recheck my results.
vitormhenrique
Post by vitormhenrique » Fri Jan 06, 2017 11:39 am
billyd wrote:I love firmware retract. You need to process your gcode file and swap out retract and unretract g1 moves with g10 and g11 respectively, unless your slicer supports firmware retract directly. Then just turn it on in the lcd panel. Works great.
I currently use cura, lulzbot edition, but I guess I can start using slic3r as my main slicer, cura does not have an option for pos-processing, as fas as I know, does it?
Yeah, I was very very surprised by my value, given that previous conversations stated that ABS should be around ~100 normally. My e-steps are spot on.
I'm doing my first big print now, the printer does sound like is making a little bit more noise, and putting more effort, but I guess that is to be expected.
Vitor Henrique
hrabbot
Post by hrabbot » Fri Jan 06, 2017 12:28 pm
Vitor Henrique
Stupid question: If I'm flashing through Cura's firmware update function, which do I need? I don't remember needing to care about this with other RAMPS, etc firmware flashes. Thanks!
Sebastian
Post by Sebastian » Fri Jan 06, 2017 12:43 pm
Regarding advance features like LIN_ADVANCE, it's not important if you use FW retract or not. Most slicers doesn't offer a lot of retract options, so FW retract is more flexible, but inside the Firmware it's leading to the same processes in the end.
I'm also surprised about K=60 should be the best. If we are all using more or less stock TAZ5 hotends, K should be the same at all printers within one material used.
But I would recheck your second statement about e-steps. Your pictures tells another story, where the scars from the travel moves are the strongest indicator. The excessive material is building up at the sides of the infill traces, during the travel move the nozzle is digging through that.
billyd
Post by billyd » Fri Jan 06, 2017 1:59 pm
Vitor Henrique
If I recall you need to use a hex file with Cura.
I recommend learning how to update with arduino direct from the code. This way you can alter and keep a record of the PIDs for your extruder(s) and bed, and also the K value for Lin_Advance, which can't be changed any other way that I am aware of. You can also learn how to add things like bed leveling and other features that can be unlocked.
