Lulzbot Mini USB Support
jkrokowski
Post by jkrokowski » Tue Jul 05, 2016 3:17 pm
After seeing a broken USB port on a Mini, we did a little design and came up with this USB support (so that solder is not also acting as a mechanical joint).
The whole idea is print one out, snap it into the opening for the USB port on the mini-RAMBO and it helps prevent the USB port from breaking off. Enjoy!
CC-BY-SA 4.0
CC-BY-SA 4.0
(More improvements likely to come)
usb_support_mini.fcstd
CC-BY-SA 4.0
(25.45 KiB) Downloaded 98 times
usb_support_mini_v1.stl
CC-BY-SA 4.0
(3.4 KiB) Downloaded 731 times
Reason: stickying for 20 days
Josh Krokowski
Aleph Objects, Inc.
+1-970-377-1111 x610
support@lulzbot.com
http://Forum.LulzBot.com
http://LulzBot.com
piercet
Contact:
Re: Lulzbot Mini USB Support
Post by piercet » Tue Jul 05, 2016 6:22 pm
Nice! Does that line up with a Taz USB port as well?
kmanley57
Post by kmanley57 » Tue Jul 05, 2016 7:04 pm
piercet wrote:Nice! Does that line up with a Taz USB port as well?
I tried my Taz 5 and my Taz 6 and they did not. :cry:
kingjamie
Post by kingjamie » Sun Nov 27, 2016 10:46 pm
Works great! See attachment.
foo_fighter
Post by foo_fighter » Tue Nov 29, 2016 1:28 pm
Works Great!
Daniel M Gessel
Post by Daniel M Gessel » Sun Dec 18, 2016 10:10 am
Does installation require opening up the RAMBO enclosure?
Edit: It doesn't want to just slide in on my mini. Do newer minis already have some kind of support added?
Last edited by Daniel M Gessel on Mon Dec 19, 2016 6:02 am, edited 1 time in total.
piercet
Contact:
Post by piercet » Sun Dec 18, 2016 11:47 am
Daniel M Gessel wrote:Does installation require opening up the RAMBO enclosure?
Nope
Brent.I
Post by Brent.I » Mon Dec 19, 2016 8:17 am
We had a little concern about customers forgetting to remove the USB support before opening the electronics enclosure. This can potentially cause damage to the board, so be sure to remove the old support before opening!
We have a new revision available that clips directly to the RAMBo board, and will not need to be removed when opening the electronics case.
Let us know what you think!
usb_support_mini_v1.0.stl
Updated Support
(111.8 KiB) Downloaded 219 times
kmanley57
Post by kmanley57 » Mon Dec 19, 2016 10:21 am
I have seen two just in the last two weeks that were not removed before 'trying' to remove the cover, and it tore the USB connector right off! :lol:
I will have to print some of these new ones out and start using them on the machines.
Thank you!
John Mc
Post by John Mc » Thu Jan 05, 2017 1:48 pm
Brent.I wrote:We had a little concern about customers forgetting to remove the USB support before opening the electronics enclosure. This can potentially cause damage to the board, so be sure to remove the old support before opening!
Since it clips to the Rambo board, does this revised design require opening up the case?
