Aerostruder chewing up PLA... Anyone else?
Have questions? Want advice?
wermy
Post by wermy » Fri Jan 19, 2018 9:45 am
I ran into the issue of the hobbed bolt chewing through PLA semi-frequently with the stock toolhead (Taz 6 and sometimes my Mini as well). When the Aerostruder was announced I was excited, thinking that a totally different hotend and toolhead design would have a good chance of eliminating this issue for good. I did several long prints just fine and thought "Great! Must be fixed." Nope. Last night it chewed through the filament a few hours into a print. Re-tried the print twice this morning and both times it chewed through it within a couple minutes of starting the print.
Anyone else experiencing this? I tried increasing my z-offset to make sure there wasn't too much pressure, messing with retraction speed and distance, and printing a little faster (to hopefully lessen the chances of heat creep), but none of those seemed to help.
I'm pretty bummed, because once I had a few prints on the new toolhead I went ahead and ordered one for my mini as well.
forg0t
Re: Aerostruder chewing up PLA... Anyone else?
Post by forg0t » Fri Jan 19, 2018 2:32 pm
Try tightening your tensioner. It sucks getting to it but mine was chewing up wood PLA until I tightened it.
Orias
Post by Orias » Fri Jan 19, 2018 2:45 pm
Directly behind the silver thumbscrew on the Aerostruder is a tiny window. A nut should be visible in this window, ideally in the middle of that window range. Adjust as needed, some materials may like more or less tension.
You may also need to adjust the extrusion temperature hotter or cooler by 5 degrees or so, as the different colorants used by different vendors will influence the ideal extrusion temperature. Reach out to our support team for help, include the slicing profile use, the filament vendor, and color: LulzBot.com/Support.
ScottW
Post by ScottW » Sun Jan 21, 2018 12:07 pm
I'm having this same problem, but with Lulzbot brand ABS on the Mini Aerostruder. Tested using the same print about 15 times yesterday. Each time, it would print perhaps 10-20 layers, then grind out the filament.
I know all the typical causes of grinding, and tried all the typical solutions... I tried different idler tension from very loose to very tight, everywhere in between at 1/2 turn increments. I tried increasing temp. Cleaned the hob after every grind-out. Checked that temp is stable during extrusion, that heatsink fan is running and heatsink is cool. Priming flows freely, no pigtailing, no clog (even tried a second Aerostruder to eliminate possible nozzle/heater/thermistor issues). Filament is dry. E-steps are calibrated. Spool is turning freely.
I played around with retraction settings. Started with default CuraLE retraction, 1mm @ 10mm/s. I tried less retraction (0.5mm), more retraction (2mm), slower (5mm/s) and faster (15mm/s). None of that helped. Turning off retraction entirely solved the problem, but made for a messy print. The print doesn't have excessive retractions -- perhaps 5-6 per layer -- and never in rapid succession.
The same part, printed with the same retraction settings, succeeds at 0.25 layer height. At 0.38 layer height it grinds out after a few layers. Also note that this part has 80% infill, so when printing infill a lot of filament is being extruded quickly -- so back-pressure may be involved. Temp graphs shows stable temp during that, but I tried increasing temp anyway from 240c to 245c, then 250c, along with different idler tensions, but still had problems. I tried reducing infill speed to 40mm/s, but the problem still occurred.
Swapped in a second Aerostruder and experienced the same problem. After fighting it all day, I finally switched back to the Hexagon and had success first time.
Over the previous few days, I had run a bunch of PETG, PCTPE, and Ninjaflex prints through the Aerostruder -- and never had a single grind-out problem. But all of those prints were also smaller layer heights, few retractions, and a bit slower (a lot slower with the Ninjaflex).
My current conclusion: The Aerostruder has a high tendency to grind out filament, at least when high flow / nozzle pressure is coupled with even a low frequency of retractions. I don't see any logical reason for it, but that's my experience so far. If there's an adjustment or setting that fixes it, I certainly haven't found it yet.
EDIT: Just ran a 2hr print, same filament, same 0.38 layer height, same idler tension, and this one had a LOT of retractions -- but almost no infill. It completed fine, no grinding despite hundreds of retractions. So again, the problem seems to be retractions in combination with high volume extrusion, as seen with doing a lot of thick layer infill.
caylan
Post by caylan » Mon Jan 22, 2018 9:48 am
I'd like to know if others are having issues, too.
wermy
Post by wermy » Mon Jan 22, 2018 9:56 am
Playing with the idler tension (boy that thing is a pain to adjust now) seems to have fixed it in my case. The window of the amount of tension that will work seems to be much smaller on this than on the original toolhead.
ScottW
Post by ScottW » Mon Jan 22, 2018 10:28 am
@wermy - What tension setting(s) worked for you, for which filament(s)? I've searched around for recommendations, but everything is really vague. Maybe we could share, at least as a "starting point", what setting(s) work for what situations.
I was using 2 turns from "full loose", and had lots of success with PETG, PCTPE, and ABS. Ninjaflex fed fine at 2 turns, but was underextruding -- lessening tension to 1.5 turns helped (still needed to increase flow to 115-120%).
For sure, with that small stiff spring, even a small adjustment (like 1/4 turn) can make a big difference in the amount of pressure applied -- so that could be the answer. With the print that kept failing for me, I tried everything from 1 turn (least pressure) to 4 turns, at 1/2 turn increments. Maybe I should have tried 1/4 turn increments?
I've only had problems with specific prints (as mentioned in earlier post). The prints I had problems with were those that had both some retractions AND a high extrusion rate (i.e., thick layers and lots of 80% infill). Everything else has printed just fine.
wermy
Post by wermy » Mon Jan 22, 2018 11:09 am
I'll have to check when I get home but it was definitely on the looser side. A modified carriage that allows you to tighten it easier would sure be nice.
As a side note, that thing can get TIGHT. I mistakenly tightened it in stead of loosening it, and the filament came out pill-shaped because it was squeezing it so hard. :O
tacit_caster
Post by tacit_caster » Mon Jan 22, 2018 2:25 pm
One other thing I would check Wermy is the idler after a clog. If my Aerostruder clogs I find that the hobbed bolt has a lot of filament residue in it, so make sure to clean that out before the next print with compressed air or a dental pick. If you want to post the gcode you are trying to print we can take a look at it and see if there is anything problematic either with the print or settings.
HETZER
Post by HETZER » Wed Mar 14, 2018 3:18 pm
I experıence the same problem with ABS. Did not try any other fimalement yet.
Does anyone have an idea for the optimum spring tensioner?
