Wanted - Taz 6 - Removable flexible bed mod ideas
BusterCherry
Re: Wanted - Taz 6 - Removable flexible bed mod ideas
Post by BusterCherry » Fri Oct 12, 2018 5:08 pm
kcchen_00 wrote:
Wed Mar 07, 2018 12:15 am
As for the 5mm PEI, it would be an expensive experiment. A sheet is ~$100. But then again if its not going to be nicked by tools, it becomes less of a consumable. Just need to scoff the surface every so often to reinvigorate the surface.
There is an old thread about testing with the PEI. Some posts cite that the PEI in thicker sheets bow when repeatedly heated, which is concerning. But there are positive posts from people that haven't experienced this. It could simply be laying the PEI down so that it curves into the metal bed, and the corners are secured by the metal fasteners.
Are there sources for 5mm thick PEI sheets? I haven't been able to find a supplier.
kcchen_00
Post by kcchen_00 » Fri Oct 12, 2018 6:27 pm
Menissalt
Post by Menissalt » Mon Feb 04, 2019 2:04 pm
Something like this would be a huge QoL improvement
dysan
Post by dysan » Mon Feb 04, 2019 9:59 pm
I don't think thick pei would be a good choice since pei is more of a thermal insulator than a conductor. When the pei is thin it's not much of an issue when if it is thick then that's an entirely different ball game.
https://www.makeitfrom.com/material-pro ... rimide-PEI
Menissalt
Post by Menissalt » Wed Feb 06, 2019 3:34 pm
I wish I knew more about metals, magnetism, heat, and where to source the materials. With my BlTouch mod a magnetic flexible bed would be a perfect compliment.
kcchen_00
Post by kcchen_00 » Thu Feb 07, 2019 12:52 am
Magnets + Modular heat bed + Buildtak Flexplate w/PEI
dysan
Post by dysan » Thu Feb 07, 2019 10:54 am
I am going to try a heatbed I found on Aliexpress which is a 300watt PCB style with a 3mm aluminum plate and it comes with a spring steel sheet already. The heatbed has magnets under it similar to what the newest Prusa has. Supposedly high temp magnets so it should work at 110c. Long wait time to get it unfortunately.
I'm going to set it up so I can level the bed with screws and at the same time remove the linear rods and go to 2 mgn12H linear rails.
I've switched my Taz 6 over to a Duet Wifi mainboard and I have a BL-Touch on it for mesh bed leveling now.
Here's the link for the heated bed I'm going to try.
https://www.aliexpress.com/item/3D-Prin ... 12466.html
And fyi, Mcmastercarr sells high temperature magnetic sheets you could use that are rated for temps up to 250*F or 121C. The only downside is they are only 9" wide so you would have to piece it together. You can get them 9" x 24" https://www.mcmaster.com/flexible-magnets and scroll down.
Another option for US based magnetic spring steel bed is a the new Wham Bam system which was a kickstarter that is now complete and for sale. You could need a heater though since it just goes on top so you could adhere the magnetic sheet to the existing glass if you remove the PEI and use it that way.
https://whambamsystems.com/
